82 Carpet Replacement
Old Oct 5, 2008 | 07:21 AM
cpmman's Avatar
cpmman
Default 82 Carpet Replacement
I would loke to replace the carpets in my 82 and would like to know best place to buy and what type of adhesive is best to use.
Is there any tricks or advice anoyne could give me to help me do a better job?
Thanks in advance for your advice
Old Oct 5, 2008 | 08:54 AM
Durango_Boy's Avatar
Durango_Boy
You can get some great quality and fit carpet sets from Wilcox.
Old Oct 5, 2008 | 09:26 AM
LannyL81's Avatar
LannyL81
Almost everyone offers carpet kits....trouble is choosing one and hoping that it fits good. I got mine for my '81 from Auto Custom Carpet...color was perfect....fit was not, and since the edges of the carpet were finished, I could not just trim to fit. I do not know who actually makes the carpet kits; hopefully others will add what vendors have the kits with the good fit.
One thing to do when you do your carpet replacement is to put the heat insulation down and also some for sound.
Good luck with it.
LannyL81
Old Oct 5, 2008 | 09:45 AM
cpmman's Avatar
cpmman
Where do you get heat insulation?
I am about to order from Wilcox as they have good feedback and the price seems to be right.
Thanks advice and reply...
Old Oct 5, 2008 | 10:13 AM
AimHigh's Avatar
AimHigh
Wilcox is good, so is ACC. I automatically assume trimming is involved in a new carpet set, I have never seen one just drop right in. Then again I am a perfectionist at fit.
Old Oct 6, 2008 | 01:37 PM
RonR80's Avatar
RonR80
St. Jude Donor '09
I agree with the above , Wilcox ,I did my whole interior last year and it fit great,don't forget the matt under the carpet ,Home Depot 15.00 and it cuts down the heat and noise works great!!!! Ron
Old Oct 8, 2008 | 09:25 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Ron and all, Thanks for the props!
Ron, not to Hi Jack the thread, but what is the cut off on Canadian import tax on cars and parts? I was under the impression that anything over thirty years was exempt?
Is this true?
Willcox
Old Oct 9, 2008 | 11:51 PM
Steve COSD's Avatar
Steve COSD
The biggest problem that I had is the side panels for the center console. The old panels are made of a hardboard material. This causes the mounting screws to not hold properly and where the carpet is supposed to tuck under the console all you can see is the edge of the carpet. What I did is get some sheet aluminum that is in the neighborhood of about 3/32 inch thick. Use the old panels as templates. Glue the carpet on with spray adhesive.
Good Luck,
Steve
Old Oct 11, 2008 | 09:59 PM
0Willcox Corvette
Former Vendor
Steve,
We have the fiberboard panels available, and when we install them the carpet sections are a little larger than the panels. We just scoot them upward on the panel a little bit. If you do this it will not show the edge of the carpet and the shift console plate and the parking brake console actually has a ledge in it to allow the carpet to fit up in to it when done this way.
Most old panels will have screws pulled through them. To correct this problem you can use the interior trim washers under the screw. This allows for more bite in the panel and will not allow the Phillips head screw to pull through the panel.
IMHO,
Willcox Inc.
To 82 Carpet Replacement
