Wiper power with key off?
Old Oct 5, 2008 | 03:57 PM
glo's Avatar
glo
Default Wiper power with key off?
My wiper motor has power with the key off and out,also my dome light stays on would this be a relay or do I have a short and need to start looking .Where would be a good start.
Gary
Old Oct 5, 2008 | 05:01 PM
GlockGuy's Avatar
GlockGuy
If your starter is wired wrong the wiper will will have constant power, the wper motor will get hot and ususally smokes.
http://forums.corvetteforum.com/show...wiring+starter
Old Oct 5, 2008 | 05:46 PM
glo's Avatar
glo
Default wiper power with key off
I have bat. cable and red wire to starter lug,and also purple wire to starter. black to ground on frame.
Gary
Old Oct 6, 2008 | 08:25 AM
jnb5101's Avatar
jnb5101
there's two wires that go to the wiper, besides the three wire plug. one is a ground and the other goes to a wire that comes out of the wiper motor. both have the same type of connector. be sure that you don't have them mixed-up.
Old Oct 6, 2008 | 09:33 AM
GaryS's Avatar
GaryS
What year? Not that it really matters, though.
The situation is not normal.
Old Oct 6, 2008 | 10:45 AM
gbvette62's Avatar
gbvette62
What year? It does matter as far as the dome light problem. Starting in the late 70's, these cars had a timer that delayed when the interior lights turned off.
Why is it that so many people post questions and never tell what year they're working on?
Old Oct 6, 2008 | 12:05 PM
Young69Owner's Avatar
Young69Owner
[QUOTE=gbvette62;1567364582]:Starting in the late 70's, these cars had a timer that delayed when the interior lights turned off.
QUOTE]
I just wanted to point out how advanced this would have been for the time considering most cars didn't get this until the 2000s. I'm impressed. I'm just glad I have mine working!
Old Oct 6, 2008 | 04:59 PM
GlockGuy's Avatar
GlockGuy
According to his profile it is a 1977.
Dome light problem might just be the door jamb switch.
Old Oct 6, 2008 | 06:27 PM
glo's Avatar
glo
My car is a 77 corvette ,the light will stay on for hours if I let it.
Old Oct 7, 2008 | 05:13 AM
65GGvert's Avatar
65GGvert
The dome light will come on when the dash dimmer switch is rotated to the full up position. The wiper power with key off does sound like a wiring issue. I had a 67 once that had power on the wipers and if I turned on the radio the wiper would move. If I turned on the fan, the wipers would stop. All with the switch off. I had +12 volts on the chassis with ground on meter connected to the positive battery terminal (reverse from normal). There were other issues too. The mechanic who rebuilt my engine had connected the starter wires wrong. The battery would run down in about 20 minutes.
Old Oct 7, 2008 | 07:15 AM
Fonz69's Avatar
Fonz69
My 69 does the same thing with the wipers, they are powered all the time.
I did a battery drain check using a light in between the cable and battery and it was not causeing any drain on it.
There was just power to the wiper switch when the key was off also.
To Wiper power with key off?
