Bringing her back
Old Oct 7, 2008 | 11:38 PM
Doug Maitlen's Avatar
Doug Maitlen
Default Bringing her back
My 79 has been sitting for a little over six months. What all do I have to do to get her back in good running condition?
Thank you
Doug
Old Oct 7, 2008 | 11:48 PM
Bowerss2's Avatar
Bowerss2
check the tire pressure,
new oil
check for signs of brake fluid leaking (or any fluid for that matter, but brakes are the most common)
check all fluid levels
(if you really want, but not necessary you can prime the oil pump, but a BIG PITA if you dont already need to remove the dist)
Check the belts and rubber
oh and grease the ball joints (ever grease fitting you can find)
and in some cases, chase the critters out of the exhaust!!!
and finally HAVE FUN, peace man
-Steve
Old Oct 8, 2008 | 12:58 PM
Doug Maitlen
Do I need to worry about the fuel system?
Old Oct 8, 2008 | 01:15 PM
markdtn's Avatar
markdtn
At 6 months, I'd charge the battery and crank it up. Oil should be fine. Unless the engine is new, say under 10,000 miles, I wouldn't worry about anything special.
To Bringing her back
