L-88 drop base filter & pcv
Old Oct 8, 2008 | 09:43 AM
RRROBB's Avatar
RRROBB
Default L-88 drop base filter & pcv
1977 L-82
I have converted to an L-88 air box and have added an RPM Air Gap
manifold,1" spacer and Holley 650 DP.
I am going to use the L-88 air cleaner set-up.
What advise would you give on set-up: go with the pcv valve on the pass. side valve cover and attach to the air hose running up into the
air cleaner and run an air breather on the driver side?
the original pcv valve had 2 connection. New pcv from L-88 has 1 connection.
From the different catalogs Ecklers ,Paragon,Corvette Central it
looks as if they used any of 2-3 different set-ups using pcv and not using pcv. HELP!!!!
