New front end allignment.
Old Oct 11, 2008 | 11:48 AM
panic's Avatar
panic
Default New front end allignment.
I think i need a proper re-allignment of my '77, specially in the front end, since i have the new 9.5x15 (front) and 11.5x15 (rear) wheels with wide Hoosiers...i didnt modified it, even if i'm sure it was needed.
Actually the front, at speed, becomes too ''nervous'' and too sensible to direction changes, specially at speed along wide bends and with not perfectly smooth tarmac.
It gives you always an urgency feeling and need max attention to have it properly around, i'd like something more stable and easy to drive, need more grip at front for sure.
What figures would you advice?
Thanks.
Old Oct 11, 2008 | 11:55 AM
redvetracr's Avatar
redvetracr
Thanks.
have factory power steering??
Old Oct 11, 2008 | 11:58 AM
birdsmith's Avatar
birdsmith
You didn't specify what your current settings were, so I'm guessing at this point, but off the top of my head I'd say you're 'toed out' too much and/or there are some uncorrected bump-steer issues at play. Check the toe and see where it's at.....if it's toed out reset it to zero and see what it does; if the problem still exists check bump steer. I'm not sure about this but there may be some kits out there that address this issue by correcting tie rod end height (there are for Fords....). Good Luck!!
Old Oct 11, 2008 | 05:26 PM
panic's Avatar
panic
[QUOTE=redvetracr;1567427003]have factory power steering??[/QUOTE
Yes..
Old Oct 11, 2008 | 07:33 PM
wombvette's Avatar
wombvette
Wide tires need as much more caster than stock. Add as much as reasonably possible.
Old Oct 11, 2008 | 08:54 PM
rponfick's Avatar
rponfick
If you drive the roads of the Amalfi coast in the car in your profile, you have much more guts than I do. It sure is beautiful, but the road is a bear.
Ralph.
Old Oct 11, 2008 | 10:00 PM
PeteZO6's Avatar
PeteZO6
Hi Panic,
I'm not trying to be a smart a$$ here, but you may be expecting too much from the car. The suspension was designed around 1960 (almost 50 years ago!) and was compromised by having to use stock Chevy front suspension parts. Even set up properly these cars won't handle nearly as well as even a C4 let alone a C5 or C6.
The trailing arm design has built in squat and raise during acceleration and braking, so even small throttle adjustments in a corner will upset the "set" of the car.
My '69 has completely rebuilt front and rear suspension, new steering components including the steering box, and a plastic rear spring; it's pretty twitchy going around corners compared to my C5 & C6 ZO6s. I've followed well set up C3s in my Zs, and I can see them twitching all over the place while I just sit back behind them totally relaxed and feeling nothing but the gentle G forces.
I'm sure you've driven modern European cars and know how well they handle - you can't expect a C3 to be like that without serious suspension work.
PS. Your car looks GREAT!!!
Cheers,
Pete
Old Oct 12, 2008 | 01:44 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
I'm no fan of the factory PS.
BTW, current alignment specs?
Old Oct 12, 2008 | 02:23 AM
panic's Avatar
panic
I think they were those given on V&P site, i've done that a couple of years ago, i remember i took the car to a good garage for the shop and we've spent nearly half a day...BTW the guy got crazy with the front shims out and in.
SW, i forgot the exact figure.
Old Oct 12, 2008 | 02:32 AM
panic's Avatar
panic
Originally Posted by PeteZO6
Hi Panic,
Cheers,
Pete
Pete, the car has the ''numbers'' to do better then it's doing right now, infact i've gone to a couple of hillclimbs with the previous wheels/tires/alignment set up and people couldnt believe the time i achieved (compared to pro drivers and race cars set up for the purpose), of course taking a few risks around bends.
My '77 weights only 1.260kgs (and that alone is half the job), has new susp rear/front, new willwood braking, 575hp powerplant and caring hands (mine) that know how to take the juice out of her....
No, the car is twice as good as it is now for sure, need to redo the allignment, specially front end.
Old Oct 12, 2008 | 04:23 PM
gkull's Avatar
gkull
I have similar hoosiers. I have found that "Zero toe" and my max 4.2 degree caster is about the best. I was running the front 10X25X15 until I went to bigger brakes and now I use the 295X35X17 R-6
Camber can only be set with a pyro meter. I don't have much vertical movement, so bump steer is not much of a concern.
Without a 6-8 point roll cage you can not increase spring rates passed about 550# front, because you just induce frame flex.
I've also gone to 1/8th rear toe to scrub the rear tires so they don't cool off in long straights
Old Oct 12, 2008 | 06:07 PM
panic's Avatar
panic
Ralph.
Well, along the first 10 miles from the beginning until Positano is really a driver's paradise, even if difficult and extremely dangerous, infact if you went off the road to your left you'd crash into the mountain rocks, if you unfortunately went to the right you have a quartermile fly into the sea but, still, crowds of enthusiasts meet on that road the weekends, specially saturdays afternoon and sundays early morning
I used to drive the grey Griffith (...and my bikes) on that road, the vette is in Spain where i live at the moment.
Old Oct 12, 2008 | 06:08 PM
panic's Avatar
panic
Thanks GK, good advices and infos here.
Old Oct 12, 2008 | 06:39 PM
gkull's Avatar
gkull
Pulling in after a 3-4 lap hot laps 4.2 mile during session I have about a 173 - 182 tire temp. The Hoosiers work between 150 and 200 and get greasy above 200.
The best thing for the front end I have done is to go to the coil over QA1 dual adjust. My tires stick out past the body and I'm able to crank the height up to clear the tire body contact
Old Oct 12, 2008 | 06:59 PM
V-Twin's Avatar
V-Twin
Are you setting it up for track, hillclimb or the road? if the road, setting camber with a pyro is BS!
The problem is most likely NOT the alignment by itself but your front wheels, see with only about 7 degree of kingpin inclination, some serious offset wheels and wide tires, you have a huge scrub radius.
Need more grip? Smaller sway bar and softer shocks/springs so you don't excessvly side load (scrub radius) the tires. Want more straight line stability? toe in and/or more caster
Old Oct 13, 2008 | 02:01 PM
gkull's Avatar
gkull
20+ years ago I was actively competing in SCCA solo Auto-X. All I was using in "BSP" was good "V & Z" rated street radial tires. I was able to determine correct camber and air pressure for my Vette with a pyrometer.
All you need to do is find a big enough parking lot to draw a 100 foot or even better 200 foot diameter skid pan. I did the skid pan thing for time at an SCCA event which when timed can be extrapolated out to lateral "G" force.
It's easy to hot lap 5 CCW and then 5 CW and then 2-3 CCW and stop and have somebody quickly do a pyro.
Yes this tells you if your street tires are getting the max use out of the tread.
Old Oct 13, 2008 | 02:06 PM
V-Twin's Avatar
V-Twin
Setting up your camber like that assumes that you are running on the street as if you were in auto xor whatever. For full out cornering the camber requirements for max. contact are different than on the street where you will be driving in a straight line and doing light cornering most of the time. If you set up your static camber to compensate for body roll in racing type conditions you will end up with far too aggressive settings for on the street resulting in uneven tire wear. Like I said, doing it this way is BS! It doesn't tell you if it gets the max out of the thread, it tells you that for the conditions you simulated when warming up the tires.
To New front end allignment.
Old Oct 13, 2008 | 07:32 PM
gkull's Avatar
gkull
You get that twin turbo monster of yours on the road and then tell me how often you are going to be doing the max effort turns
When I drive on street tires I need the most traction I can get. I'm not concerned with how long my tires last.
Old Oct 13, 2008 | 07:47 PM
V-Twin's Avatar
V-Twin
That's Marcks car, I have a 77 and there's no turbos on it or anything.
What I meant to say was, when reading tire temps on a track or auto X and then dialing in the camber to maximize the contact area and even out the temps across the tire, this is representing the actual driving you do, so a lot of high speed cornering and only short straight sections. As a result the static camber you dial in will be to compliment the camber curve for that style of driving. As an effect it in no way assures you have maximum straight line traction. usually you have to dial in a bit more static camber than you would want for straight line traction. It all comes down to the compromise. Now, for the street that compromise is a lot different than for the track. Setting a car up for a certain track sets it up for the unique combination of corners and straights presented on that track. On the street, it's always different unless you drive the same stretch every day, oh and the weather and all should be the same too.
For the street it's much more important to have a stable adjustment that offers good straight line stability, typical under steer to keep the back in check and so on.
Old Oct 14, 2008 | 01:43 AM
panic's Avatar
panic
Thanks for your contribution.
I think first thing i'll have to soften my front QA1, i believe they're too hard by at least 3/4 steps...
I would like to summerize all the advices in figures front and rear please, taking in account that it's a street one but that often i drive like i was on a ''track'', specially on highways...and the large front/rear Hoosiers.
