69 Ignition Switch Question
Changing the ignition lock cylinder (in the column head) is not that bad. Changing the ignition switch (on top of the steering column jacket down under the dash) requires that you drop the steering column. This location makes the car harder to steal by hot wiring it. It also makes it more difficult to service the switch.
To remove the lock cylinder you will need a steering wheel hub puller and a locking plate compresser tool. You can usually borrow, rent, or purchase them from various sources.
Complete instructions on Disassembly & Repair of your steering column can be found at:
www.corvettefaq.com
click on Jim Shea's Steering Papers
click on Corvette Steering Papers
scroll down to either the 1969-79 Standard Column section or the 1969-82 Tilt & Telescoping Column section.
Download the appropriate Disassembly & Repair Paper #1 and Pic #1. These papers will walk you through replacing the lock cylinder.
To replace the ignition switch you will also require D&R Paper #2 and Pic #2 & #3.
Jim
Jim
Jim
Jim
Jim if the T&T was loosening up couldnt this cause a push one way on the column to give the rod just enough more to start?Seems I remember by pulling up on the steering wheel this will allow the rod to move enough sometimes.
mhc64 try turning your key to start and pulling up on the steering wheel at the bottom and see if this helps.
Turning the bowl counterclockwise would be the same as moving the lower lever to the UP position. So now it seems as if your problem is the cable from the transmission and the lower column lever. The only adjustment for the cable is to loosen the two nuts at the bottom of the column near the floor (inside the car - under the dash.) With them loosened you should be able to move the heavy metal plate that is in the engine compartment under the brake booster and get a limited amount of adjustment of the cable with respect to the lower lever.
It could be that your ignition switch is also out of adjustment as well. BTW, I posted a complete writeup on adjusting the ignition switch on the "NO KEY START" topic about two days ago on this same forum.
Jim
