1977-Remove Horn button
Old Oct 13, 2008 | 02:54 PM
fastcw's Avatar
fastcw
Default 1977-Remove Horn button
Does the horn button need to be turned CCW a few degrees to come off?
Mine will turn, but doesn't come off with a little bit of force.
Before I use some more force and break something, how do you get the button off?
Old Oct 13, 2008 | 03:05 PM
wnmech's Avatar
wnmech
On my 77 it just pulls off. It probably hasnt been off for years and is just stuck.
Durango_Boy's Avatar
Durango_Boy
Use a rag to guard the painted surfaces, and a long and thin flat head screw driver. Get in under the spring loaded metal teeth, and pry up. It'll pop out. Usually they just get a little bit rusty and stick in place.
To 1977-Remove Horn button
