Fuse block replacement help.
Old Oct 14, 2008 | 08:53 PM
Independentvette1's Avatar
Independentvette1
Cruising
Default Fuse block replacement help.
My fuse block is damaged and I want to replce the the fuse block, is there a difference with a four speed/automatic or with or with out airconditioning. Any help would be very appreated.
Old Oct 14, 2008 | 09:42 PM
aussiejohn's Avatar
aussiejohn
Inde,
If you have a C3, then I'm pretty sure that one fuse block is pretty much the same as another. I'm no expert here, but they all appear to have the same number of recesses and cars that have extra power accessories will have more fuses fitted. It's not uncommon to find a lowly spec'd car to have several empty spaces in the fusebox.
Regards from Down Under
aussiejohn
10 months to go
Old Oct 14, 2008 | 10:34 PM
Independentvette1
Cruising
This is for 1972 coupe, with an automatic and air conditioning, I was told there is a difference in the fuse blocks when replacing it on a 72.
Old Oct 14, 2008 | 10:36 PM
7T1vette's Avatar
7T1vette
Several years have the same block...but it changed every few years. Mind telling us what year car you have?
Old Oct 14, 2008 | 10:46 PM
Independentvette1
Cruising
It a 1972 coupe base 350/ automatic with air.
Old Oct 15, 2008 | 08:20 AM
jnb5101's Avatar
jnb5101
i converted a 73 wiring harness to use on a 72. other than the changes i made to operate the wiper door, most of the wiring is the same. there are several and different connectors (such as brake light) and extra connections in the terminal end for polution, etc. but if i remember correctly, all the major wiring at the fuse block is the same.
Old Oct 15, 2008 | 12:17 PM
7T1vette's Avatar
7T1vette
I believe that 68-72 use the same block.
To Fuse block replacement help.
