Power Steering Control Valve rebuild
Old Oct 15, 2008 | 01:50 AM
radiojoe's Avatar
radiojoe
Default Power Steering Control Valve rebuild
I'm rebuilding my Power Steering Control valve with this kit:
http://www.mamotorworks.com/corvette?frame=1.1368
Check out the PDF for directions here:
http://content.madirect.com/pdf/602456.pdf
I've ran into a problem though. I can't figure out how to get out the ball adjuster nut and everything below it.
Any clues? Here's a pic to show where I'm stuck at.
Old Oct 15, 2008 | 08:40 AM
LYLE's Avatar
LYLE
It's been awhile but I think you just unscrew the center part like a nut with a screwdriver in the slot. Give it a try it may work.
Old Oct 15, 2008 | 11:51 AM
radiojoe's Avatar
radiojoe
That's kind of what I thought- but when I initially tried it didn't come too easy so I didn't want to force it without checking.
Thanks.
Old Oct 16, 2008 | 08:10 AM
reelthing's Avatar
reelthing
Absolutely, thats how I did it. Your CV looks like mine did...
Old Oct 16, 2008 | 12:09 PM
radiojoe's Avatar
radiojoe
Yep it worked! I just had to give it a little more force than I expected.
Last night I actually finished rebuilding the control valve as well as the cylinder. It's pretty clear looking at my hoses that they were a big part of the leak issue I was having but the rebuilds weren't that hard to do- and a lot cheaper than buying new parts!
I also got some new hoses, man they were expensive.
To Power Steering Control Valve rebuild
