PCV valve size
Old Oct 15, 2008 | 09:05 AM
bashcraft's Avatar
bashcraft
Default PCV valve size
I currently have 2 breathers and want to replace one of them with a PCV valve. I'm using the Moroso baffled grommets because the valve covers do not have baffles. Can I get a PCV valve with a 1" body to fit in place of the breather? I remember only seeing PCV valves with a 3/4" body.
Old Oct 15, 2008 | 09:13 AM
Durango_Boy's Avatar
Durango_Boy
I know at stores like Autozone they have the PCV valves on a rack on the floor, and I know I have seen a few with a larger diameter body maybe very close to 1".
My other thought is, and this might seem a bit Bubba, but what if you were to use some rubber hose, like heater hose, and make a sleeve to act as a spacer? It would seal just fine, and the hose is the right thickness that you could easily get from .75" to 1" for a good tight seal.
I was going to be going right by an Autozone when I leave for lunch. If you like I can stop by and measure a few.
Old Oct 15, 2008 | 10:07 AM
bashcraft's Avatar
bashcraft
Thanks Matt, I didn't realize they kept these things out on the floor. I can stop on my way home from work and see what they have.
Old Oct 15, 2008 | 10:10 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
http://store.summitracing.com/partde...5&autoview=sku
Old Oct 15, 2008 | 10:11 AM
Durango_Boy
He can't just change the grommet because he is using special grommets with baffles.
Old Oct 15, 2008 | 10:55 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Your speed shop has baffled grommets for the correct PCV valve.
To PCV valve size
