on 76, I can't get windows to work thru switch.
Put power to both windows, they work. Tested both switches with ohm meter, both good. New relay, ground is good. I have power to center of relay.
Shouldn't I have power to pnk/blk wire with Ign on? Which I don't. Checked fuses all good. Ideas?
