removing the oil pan
Old Oct 21, 2008 | 07:59 PM
humphbri's Avatar
humphbri
Cruising
Default removing the oil pan
Hi everyone.
I am removing the oil pan on my 75 and in earlier posts it was suggested that you need to cut the stock exhaust to make enough room to lower the pan. Has anyone removed the oil pan with the stock 2 to 1 exhaust still in one piece? I thought that I might get enough room by disconnecting the exhaust at the converter?
Old Oct 21, 2008 | 09:08 PM
mikep3's Avatar
mikep3
Default Oil Pan Removal
I just did one on a 78, but with dual exhaust. I remember the old "Y" pipe went behind the bell housing??
You might want to search for Oil Pan on the forum, I found one by Durango and this one that spells out somethings you should consider.
http://forums.corvetteforum.com/show...hlight=oil+pan
Disconnect the Battery, remove the starter, cluch inspection plate, drop the two bolts on the ider arm to frame and maybe the PS cylinder end nut so you can get space to drop the pan, drop the pan and start cleaning the old gaskest off.
Use one of the new one piece gaskets and get some extra hands and beer for de-greasing. You will have a good laugh when there are not leaks after a long Saturday/\
Old Oct 22, 2008 | 07:44 AM
1nicecorvette's Avatar
1nicecorvette
i have done it last month (the 5 day oil change!!)
i removed the exhaust from the headers i then removed it from the straight pipe it attaches to that goes to the cat convertor DONE!!!!???? NOPE--- that sucker will leave you with 1/8th of clearance to go!! meaning drop the steering linkage. it then slips right out without problems. Make sure you have it sealed correctly as you DONT want to do this all over again!!
Old Oct 22, 2008 | 08:42 AM
Paul L's Avatar
Paul L
You may not have to go all the way back to the converter if the front Y-pipe is in good shape.
Old Oct 22, 2008 | 12:16 PM
1nicecorvette
right thats what i meant just remove TO the pipe thyat goes into the cat. I had to peel mine back a little to get her loose but if you have access to a blow torch to heat it up then it should come out no prob.
Old Oct 23, 2008 | 04:34 AM
humphbri's Avatar
humphbri
Cruising
Thanks for the advice. Unfortunately I think someone welded the joint between the y-pipe and the straight piece that goes back to the converter. I guess I'll see what happens when I get serious on the weekend.
Thanks heaps.
Old Oct 26, 2008 | 07:35 PM
humphbri's Avatar
humphbri
Cruising
Hi Everyone
I tackled this on the weekend. If you want to save yourself from cutting your exhaust, just disconnect the exhasut at the manifold, loosen the bolts on the two hanging points and remove the bolts at the cat converter. This will lower your exhaust just enough to pass the oil pan under. Mine came out without too much colorful language.
thanks again for the help.
To removing the oil pan
