81 currently with 4 spd stock trans, stock differential in CA. Looking to get some recommendations on what gear ratio would work best to upgrade to. Looking for good intown driving but need to be able to get on the I-5 highway. If you now CA, what to be able to keep up with the flow of traffic (80 or so) for 40min + and not run at 3k rpm the entire time.
If you go to the richmond gear site thiers a calculator to match any set with your tranny & tire size and tell you what RPM you,ll be running @ any speed you want.
...to be able to keep up with the flow of traffic (80 or so) for 40min + and not run at 3k rpm the entire time.
With this criteria, the stock 2.72 is as good as you can get without going to an overdrive trans.
The 2.72 should put you at 2700 rpm at 80 mph, if you are turning more revs somebody
must have swapped your gears to something lower.
Alan.....I have a 79 L82 with a 350 automatic and 3:70 differential. It's great around town, but it runs between 3500-4000 rpm on the interstate (freeway to you). At higher speeds the engine is reved up and noisey. Spedaleden is correct....unless you can afford an overdrive trans, leave the diferential alone. Plus, if you lower your differential ratio you're going to experience a sharp drop in your fuel mileage. I average approximately 11 mpg around town and 13 mpg on a trip.
