Distributor replacement
Old Oct 23, 2008 | 12:39 PM
rayluka's Avatar
rayluka
Default Distributor replacement
What is a good replacement for a 1976 HEI distributor?
Old Oct 23, 2008 | 12:48 PM
bashcraft's Avatar
bashcraft
Another HEI. You really can't do much better for a stock or mild performance engine.
Old Oct 23, 2008 | 12:50 PM
rayluka's Avatar
rayluka
Im sorry. I meant manufacturer. Or is this not a concern either?
Old Oct 23, 2008 | 02:51 PM
thegazman's Avatar
thegazman
Default thegazman
Go to Summit Racing or Jegs. They have some upgraded distributors at a fair price.
Old Oct 23, 2008 | 03:23 PM
BKbroiler's Avatar
BKbroiler
I got the basic MSD, HEI distributor from Jegs. Direct replacement for the stock unit. Works fine.
Old Oct 23, 2008 | 04:23 PM
BarryK's Avatar
BarryK
what's wrong with yours now? Chances are you can have it rebuilt for the same OR LESS money than what an aftermarket unit will cost you and the stock units were great units.
Old Oct 23, 2008 | 05:32 PM
rayluka's Avatar
rayluka
I dont know that anything is wrong. Im having odd problems with surging and bucking on WOT and since I advanced it a couple degrees the car runs better. I read Lars's papers on timing and pick up the springs tonight. If it improves I feel it may be the cause and plan to just replace it with a new unit. Ive gone thru everything else.( carb tune-up fuel pump etc)
Old Oct 23, 2008 | 05:45 PM
BarryK's Avatar
BarryK
surging is typical of too much vacuum advance.
If your distributor is not actually malfunctioning, which it sounds like it's probably not, a good rebuild and recurve is probably all it needs. That's a lot less expensive than buying a new unit!
To Distributor replacement
