u-joint bolts on '80 Auto
Old Oct 24, 2008 | 10:45 AM
red72corvet's Avatar
red72corvet
Cruising
Default u-joint bolts on '80 Auto
I couldn't find anything in my tool box that fits those 6 point bolts on the half shafts last night. I forgot to look at them this morning in my rush to get to work. Can anyone tell me the socket size that fits those little buggers so I can pick it up today at lunch?
Old Oct 24, 2008 | 01:23 PM
red72corvet
Cruising
I was mistaken I think they are actually 12 point and probably metric as a lot of other fasteners on the rearend are metric. I guess I'll just drop by Sears and pick up a full metric 12 point set. I'll probably need them along the way anyway.
Old Oct 24, 2008 | 01:47 PM
DaveL82's Avatar
DaveL82
I use a 12 point 1/4" on my 80 (not metric). I use a socket on a couple of 1/4" extensions to get the U-join of the diff through the crossmember. For the halfshafts I use a wrench.
Good Luck
Old Oct 24, 2008 | 02:04 PM
red72corvet
Cruising
Thanks, I knew someone would have the answer. A 12 point 1/4" it is.
Old Oct 24, 2008 | 02:44 PM
kevinator80's Avatar
kevinator80
If you can get one off, take it with you. I took my tranny out this past Sunday afternoon and the only thing in my box that would fit was a 1/4" 12 pt end wrench. My low quality 12 pt socket would not hold, nor would the #12 inverted torx which I think is supposed to be the correct tool. I'm just saying you may want to take one with you just to save a trip.
To u-joint bolts on '80 Auto
