Lifter selection
Old Oct 26, 2008 | 11:42 AM
hgm's Avatar
hgm
Default Lifter selection
I am looking for some dimensions from a retro hydraulic roller lifter. The measurements I need are:
Length end to end
diameter
Length from tip of roller to the bottom of the tie bar
Distance from top to the top of the oil groove
Distance from the top to the bottom of the ring groove
Thanks in advance
Old Oct 27, 2008 | 12:14 PM
Little Mouse's Avatar
Little Mouse
Length end to end
diameter
Thanks in advance
Call the manufacture of the lifters you want to use they should be able to give you some accurate measurements.
