Need help timing chain 454
Old Oct 30, 2008 | 08:43 PM
divette's Avatar
divette
Default Need help timing chain 454
Hi, all
The help is necessary. Who knows as to establish this chain. The label is between a teeth:
Old Oct 30, 2008 | 09:18 PM
sly vette's Avatar
sly vette
I would like to help but I'm sorry that I don't understand the question.
Sly
Old Oct 30, 2008 | 09:39 PM
divette's Avatar
divette
Sly
On a photo the chain is correctly established?
Old Oct 30, 2008 | 10:26 PM
TimAT's Avatar
TimAT
How many keys does the crank (lower) gear have? More than one? More than one, use the one marked "O".
The dots on the gears are correctly established when they are closest together.
Big gear dot at 6:00 and small gear dot at 12:00.
When you get them all together, and rotate the crank 2 full revolutions they will be back together.
I was close to Russia for a while, but the few words I picked up won't help me describe any better. Sorry.
Old Oct 31, 2008 | 04:46 AM
divette's Avatar
divette
I know it, only on small gear wheels "o" between teeths, such did not see earlier, your help therefore is necessary.
Old Oct 31, 2008 | 05:47 AM
noonie's Avatar
noonie
This ought to get both you guys in trouble.
Сколько ключей чудак (понижается), механизм имеют? Больше чем один? Больше чем один, используйте отмеченный "O" того.
Точки на механизмах правильно установлены, когда они являются самыми близкими вместе.
Большая точка механизма в 6:00 и маленькая точка механизма в 12:00.
Когда Вы получаете их всех вместе, и вращаете чудака 2 полных революции, они вернутся вместе.
Я был близко к России некоторое время, но немного слов, которые я собрал, не будут помогать мне описывать немного лучше. Жаль.
Try this link
http://translation2.paralink.com/
Old Oct 31, 2008 | 11:46 AM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Lower gear will have three marks on it "O" a square"[]" and a triangle "^"
You align one of those marks to to the "O" of the big gear.
"O" of big gear is placed at the 6 oclocl position as you have it.
Bring #1 piston to the top of its bore this will bring the crank key close to either the 12 or 2 oclock position (depends on year of motor).
Now you will see that the lower gear keyway are cut differently
One has a square cut in it. one is half rounded & I cant recall what the third cut is like.
I believe the half rounded cut is the one to use to install the cam at a zero degree advance.
The triangle and square marks are for setting cam advance or retard and I believe its 4 degrees for either mark
Old Oct 31, 2008 | 07:18 PM
sly vette's Avatar
sly vette
And what positive results can be expected by "locking in" 4 btc or
4 atc?
Sorry for cutting in,but this is one of those questions for me that I have always wondered about but forget to ask.
Sly
Old Oct 31, 2008 | 08:36 PM
FB007's Avatar
FB007
4 atc?
Sly
Advancing the cam 4* brings the power band in sooner, retarding it brings it in later.
Old Oct 31, 2008 | 10:34 PM
TimAT's Avatar
TimAT
Noonie, you're a show off. I never though of that. GOOD SHOW!!
Old Nov 1, 2008 | 02:54 AM
divette's Avatar
divette
All thanks, it is established correctly
Old Nov 1, 2008 | 03:31 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Try this link
Now becareful when you use some of these web translators! .. I used some of them to translate a few phrases to my native tongue language, and believe me, only about 40% is correct, and the rest were some VERY funny words!!
Old Nov 1, 2008 | 09:48 AM
dstaley's Avatar
dstaley
You ARE going to be degreeing this cam in anyway, right? Mistakes in being "one tooth off" are quickly apparent when you confirm that the cam timing is as expected.
EDIT: Put the engine at exactly TDC then you don't have to worry about which crank gear tooth to worry about. Use a ruler between the cam centerline and the top of the crankshaft to line up the camshaft tooth.
Old Nov 1, 2008 | 05:26 PM
lars's Avatar
lars
Keep in mind that the engine is on the exhaust stroke when you put the cam dot at 6:00 and the crank at 12:00 - you need to put both dots straight up at the 12:00 position if you're going to drop the distriubutor in the engine and get it timed. If you put the distributor in with the cam dots pointed "together" the distributor will be 180 degrees out.
Lars
To Need help timing chain 454
