Machine block work II
Old Oct 31, 2008 | 12:54 AM
boat196's Avatar
boat196
Default Machine block work II
Max performance with stock apperance 70 L46. I made my mind up to rebuild the # matching block. Disassemble the short block this weekend and take it to the machine shop. If their no issuses, then rebuild with all new quality parts(crank,rods and pistons) and balance,blueprint.
Bob
Old Oct 31, 2008 | 06:53 AM
dcarr's Avatar
dcarr
ttt
intrested in any replys to this one
Old Oct 31, 2008 | 12:41 PM
jackson's Avatar
jackson
assume 70 L46 350ci motor has OE heads w/ comb chamber volume that's very close to 64cc. it's stated owner wants new crank, rods & pistons AND balancing included in this rebuild.
Based on that:
build a 383 with dished (aka reverse dome) pistons.
Old Oct 31, 2008 | 01:10 PM
Lt1er's Avatar
Lt1er
Bob
what do you consider is max performance? My 71 Lt1 is rather stock appearing other than headers and lager true duals. I have probably in the low 400 hp range with a solid cam.
even with modded double hump heads like I have you're probably limited to 400 or less HP with cast iron exhaust manifolds
Old Oct 31, 2008 | 02:09 PM
BLOCKMAN's Avatar
BLOCKMAN
Bob
What do you mean by blueprint, main line, cam tunnel, lifter bores, decks, cylinders, ETC thats alot of money spend on a block.
Old Oct 31, 2008 | 02:55 PM
boat196's Avatar
boat196
The cylinder heads (#186) minor pocket porting and CC'd. Intake GM performance cast iron version of the LT-1. 2.5" iron manifolds. I want to keep a stock apperance, I'll retain L46 cam, keep the compression at 10.25:1 I though of buying new crank ,rods,pistons (lighter and stronger) pistons and rods I have to buy anyway. Machine work not to sure, tell the machine shop has inspected the block. My idea of blueprinting to check and measure and correct accordingly with in reason. I know that the HP will be limited thats fine for my car. I'm throwing this out their to get feedback to help me make decision's when the time comes for the rebuild and machine work.
Bob
Old Oct 31, 2008 | 03:57 PM
b71vette's Avatar
b71vette
if it's a matching numbers block be sure they don't machine the serial numbers off the block.
To Machine block work II
