speedometer error
Old Oct 31, 2008 | 02:19 PM
palazzopl's Avatar
palazzopl
Default speedometer error
I removed my cruise control on my 81 auto and replaced the cable direct to the tranny. Now it reads 5 mph higher at all speeds. Do I need a different tranny gear..
Old Oct 31, 2008 | 02:23 PM
...Roger...'s Avatar
...Roger...
Are you sure that the extra 5 is not correct? I usually do the milemarker thing on the highway. 5miles =5 min.
If it is off then yes you can change the trans gear.
Old Oct 31, 2008 | 02:43 PM
palazzopl's Avatar
palazzopl
I checked the MPH with my gps still 5 mph high
Old Oct 31, 2008 | 02:51 PM
...Roger...
Oops forgot about the new high tech stuff....barely know how to spell gds
I think your going to need about 2 more teeth on your gear.If I remember right its about 2.5 mph per tooth.Someone should pop in and confirm.
Old Oct 31, 2008 | 03:01 PM
wombvette's Avatar
wombvette
It shouldnt have made any difference. Its direct drive.
Old Oct 31, 2008 | 03:32 PM
palazzopl's Avatar
palazzopl
the original came with a two piece cable with the cruise module in the middle. now it goes direct to the speedometr
Old Oct 31, 2008 | 03:33 PM
palazzopl's Avatar
palazzopl
the original came with a two piece cable with the cruise module in the middle. now it goes direct to the speedometer
Old Oct 31, 2008 | 05:43 PM
7T1vette's Avatar
7T1vette
Theoretically, it shouldn't change. But, the transducer may have been slipping and had a gear change already. If it reads too high, you'll need a gear with 1 or 2 more teeth.
Old Oct 31, 2008 | 07:58 PM
DC3's Avatar
DC3
Mine was reading high due to the smaller tires the previous owner put on. I corrected mine by going back to the correct tire height when I changed tires and wheels.
If you happen to be in need of tires, you could affect the change you want by selecting the right size tire.
DC
Old Nov 1, 2008 | 09:57 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
A good rule of thumb here is 1 tooth = 5 mph. You need 1 more tooth.
Willcox
To speedometer error
