restoration project day two - it runs
Exactly one day after buying the car and getting it pushed into the garage, we had a locksmith come out and re-key the ignition for me. Hooked up power source, checked fluids and what do you know...this baby fired right up. Best estimates is at least one year of sitting between owners. Didn't even have to change the plugs (obviously will be step one once its road ready) and it cranked right over and fired! You have no idea how relieved i am for a first time restoration. I understand there are far worse condition cars out there; and i am only doing a body-on restoration not the whole 9 yards...but with no guarantees it would run or there was any life to this heap, it boosted my confidence! Not wishing to throw away my good luck, we even tried some of the electrical items among the piles of wiring harnesses in the gutted interior. With a little poor man's splicing we even got the power windows to go down. This sucker even has turn signals...no seats or anything resembling an interior but i can signal with the best of them
Anyway, tomorrow is another day and i'll start the actual undercarriage prepping so i can attempt to install some stopping applications to this now running 36 old bell of the ball. Thanks for listening to the rants guys...just happy i didn't bite off far more than i can chew. For once, just once i may even be able to tell the Mrs, that i was right
i have a 70' coupe 350/350 that i bought a couple of years ago, it had sat in the same spot for 20years (only 50k mi) and no one had even tried to start it. i took it home, cleaned out the gas tank, pulled the carb and cleaned it out, put new points and plugs in it. changed all the fluids, and squirted some WD-40 in the cylinders. it FIRED RIGHT UP! runs like a top. and..........all the electrical, fibre optics, lights etc worked. EVEN THE CLOCK! so, ya never know. the guy parked it 20 years ago because the brakes went out, and he didn't want to spend the money to fix them. rick
Here is one example of spray on under car coating.
http://www.autogeek.net/under-coating.html
I can tell you from experience its taken me about $40 worth of $0.99 cans of spray paint to spray "something" on the bottom of my car. I'm not sure how the cans per square foot would translate with this stuff because its thicker but I would expect that it would coat with less passes & not go as far.
Be very glad you're fixer-upper has given you some good things that work. Believe me, it could have gone the other way where nothing works.
