shifter seal
Old Oct 31, 2008 | 09:01 PM
carhound's Avatar
carhound
Default shifter seal
What is the easiest way to replace the shifter seal on the side of a 400 turbo transmission? I can't get the seal out because of the tight working area. Any suggestions?
Old Oct 31, 2008 | 09:09 PM
noonie's Avatar
noonie
This is a link to the tool you need.
http://www.thenerds.net/KD_Tools.KD_....html?affid=41
Even though it's listed on many sites, it is not made or available any more.
I ended up ordering one from Snapon last summer because I can't find my old one. $30.00 shipped.
It's almost impossible to not screw up the very soft shaft if you don't use this tool. 5 minute job. It fits almost all the gm trannys.
Old Oct 31, 2008 | 10:10 PM
7T1vette's Avatar
7T1vette
Or... if the existing seal is driven deep enough, you can drive another one on top of it. As long as the seal lip rides on the full surface of the shaft journal. No need to do anything but add another.
Old Nov 1, 2008 | 02:17 AM
Mr. Beam's Avatar
Mr. Beam
Take a sharp tool and let your frustration have a go at it by prying it off.... Helped for me and it came off easier than I thought. Just watch so you don't damage the shift shaft axel.
BTW. It was the prime source for all the drops of transmission fluid.
Mr. Beam
Old Nov 1, 2008 | 11:16 AM
7T1vette's Avatar
7T1vette
Yep. That is the way to remove it. You just have to be careful not to scratch up the bore surface or the shaft journal when you pry it out.
To shifter seal
