Mushroomed side yokes....
Old Jan 12, 2002 | 02:11 PM
fauxrs's Avatar
fauxrs
Default Mushroomed side yokes....
So how do you get these out of the carrier to replace them - they certainly will not pass through the spiders without complaining.
take a look at these...you can see that the yoke tips are worn ALL THE WAY to the c-clip slot - in fact it was a bit of an effort to get the clip off past the mushroomed part - even with the correct tools.
One thing that really pisses me off is a corvette shop that I trust(ed) replaced the drivers side yoke no less than 2 years ago - judging from the equal amount of wear, I find it highly unlikely that these are anything other than the original side yokes. Even though I was charged for one when I had my posi redone at the same time. To top it all off - dont you have to take the yokes and spiders out to get to the plates behind the spiders????
Anyway the question is - how do you get these things out of here so I can put in new ones?
Old Jan 12, 2002 | 02:45 PM
Monty's Avatar
Monty
Default Re: Mushroomed side yokes.... (fauxrs)
When I rebuilt my diff a couple of years ago, I faced a similar situation. I just used a hammer and long drift on the back side of the yoke. I tapped on the back of the flange where the ujounts go, and they eventually came out. This method basically used the side gears to remove the mushroomed metal off the yokes, but they were not damaged since they are made of a harder material.
Old Jan 12, 2002 | 02:48 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
my suggestion is a dremel, steel cutting bit and an hour or two of patients. i've done alot of metal working with those little dremels and if you can get it in there it will work. polishing a set of 2.02 heads with one right now.
Old Jan 12, 2002 | 03:15 PM
MIKER's Avatar
MIKER
fauxrs,
I first tried using the "dremel tool" method. It will work but I was bothered by all of the metal shavings collecting in the rear end. This is probably not a problem because it can be cleaned up after disassembly but I ended up using Monty's idea and it worked great.
Clutchdust,
I agree, a Dremel is a great tool to have. Mine has pulled me out of a bind many many times. To anybody who doesn't have one. . . GET ONE!
Old Jan 12, 2002 | 03:16 PM
fauxrs's Avatar
fauxrs
Default Re: Mushroomed side yokes.... (MIKER)
well I have a dremel as well and I also have the tools required for the other solution - will let everyone know how it comes out.
Old Jan 12, 2002 | 03:33 PM
Gordonm's Avatar
Gordonm
It should come out with tapping it out. The metal that is mushroomed over will break off and the yoke will come out. It will take a little effort but they will come out.
Old Jan 12, 2002 | 04:01 PM
fauxrs's Avatar
fauxrs
Default Re: Mushroomed side yokes.... (Gordonm)
How right you are - Tapping was my first thought but I was looking for a little confirmation. some judicious whanging with the pickle fork and mallet netted me this.
Im starting to document all of this on my website = suspension section.
thanks for the help - as always - one can count on the forum membership.
Old Jan 12, 2002 | 06:54 PM
GTR1999's Avatar
GTR1999
How much end play did you have with these, I'm guessing about .200". What are you going to do with them, trade in or weld the ends?
Gary
Old Jan 12, 2002 | 06:58 PM
fauxrs's Avatar
fauxrs
Default Re: Mushroomed side yokes.... (gtr1999)
I had about .165 on the drivers side - a few thou less on the passenger side - I will be getting new side yokes - I have no plans for these as yet.
Old Jan 12, 2002 | 07:51 PM
GTR1999's Avatar
GTR1999
Well if you decide to trash them I'll take 'em to play around with :smash:
Gary
To Mushroomed side yokes....
