help lifter sound
Old Nov 3, 2008 | 04:36 AM
corieb's Avatar
corieb
Default help lifter sound
i need help my 1981 vett is making a tapping loud tapping sound and it is back firing now and it hass no power ,i tryed to tightn the lifters but one of my pushroads where bent ,how do i ajust them.
this is the first time me doing this help pls.
Old Nov 3, 2008 | 07:08 AM
baxsom's Avatar
baxsom
if you have a bent pushrod that has to be replaced first and foremost.
Old Nov 3, 2008 | 07:53 AM
Durango_Boy's Avatar
Durango_Boy
You need to do a lot more work than just adjusting the rockers. You have a bent push rod and you need to find out why.
Old Nov 3, 2008 | 04:02 PM
jackson's Avatar
jackson
? ran the heck out of it (hi rpm) .... pumped up lifters & floated valves ... bent a pushrod or two ... maybe even had a valve or two hit piston(s)?????
Better look to see if any of the 16 lifters has puked its thin wire retainer out the top of each lifter.
Old Nov 11, 2008 | 12:01 PM
corieb's Avatar
corieb
Default thanks for the input
i think out of a random act of stupidity i tightened it to tight when i was trying to get the tapping nose out of the car .
replaced all the push rods and it runs great now thanks a lot for your input guys .
Old Nov 12, 2008 | 08:16 PM
headache57's Avatar
headache57
sounds like the cam is wiped, or lifther, either way it bent your pushrod. if cam wore on one of the lopes, it frozed the lifther then bent rod, if lifther frozed first, it wore the cam then bent rod....either way, the rod wont bent on its own. one way to check cam. take off one valve cover then run motor, look to see if all the rockers are moveing the same height, if one isnt going as high, then that lope is worn on the cam. be sure to check both sides. i know this cuess i just went tro this, have to change cam lifthers rod's. good luck
Old Nov 15, 2008 | 01:46 AM
corieb's Avatar
corieb
Default replaced pushrods
when i replaced the push rods ,i watched all the lifter's very closely to see if the where all working and the oil was pumping out the top of them .
i was covered in oil after but all seamed fine and where moving about the same height and oil was spraying out of the top of them .
but it runs well now .
To help lifter sound
