74 vatte resto
Old Nov 5, 2008 | 11:12 AM
aj005's Avatar
aj005
Default 74 vatte resto
hello vette lover can use some help with my 74 vatte bring it back to life. i just presure wash the inside, engine and under the car. i need help with what type of paint to use for under the car, what can of sound stop to use, this is my first time doing this. just what your all would do if your all was in my shoes.
Old Nov 5, 2008 | 11:59 AM
Durango_Boy's Avatar
Durango_Boy
Welcome the forum.
When you say a paint for under the car, are you wanting a permanent coating or just a paint. There are several coatings, including baked powder coating, that will protect the frame and coatings you can spray to cover the underside of the body.
Usually a good flat black paint is perfect for the engine compartment.
For inside, lay down a layer of Dynamat Extreme on the hard bare floors, then cover that with a jute backed carpet, or a layer of jute, and then the molded carpet.
Wilcox is a vendor on the forum and sells molded carpet kits that have the heat barrier jute already glued on. The Dynamat is a sound deadener designed to help minimize road noise and it goes down on the bare floor.
