Starter question
Nov 5, 2008 | 06:05 PM
Starter question
I am getting ready to install headers on my 76 350 and would like to replace my old oil soaked starter with a new one. The two options that I have been thinking about : High torque mini or lightweight starter from 93-97 lt1. Any advice is appreciated. Thanks, Kevin
Nov 5, 2008 | 06:13 PM
The late model truck starters, are high torque and mini.
Edit: Excludes LS engine starters.
Nov 5, 2008 | 06:21 PM
Around what years?
Thanks for your reply and all your help so far
Kevin
Nov 5, 2008 | 06:47 PM
Quote:
Originally Posted by
Durango_Boy
I think GM changed the starter mounting bolt pattern sometime in the early 70's. Went from stagered holes to inline or something like that.
Nov 5, 2008 | 06:51 PM
Duke94
The larger flywheels, 168 tooth used a staggered bolt setup the small, 153 tooth used a straight bolt pattern. I have the mini GM starter from the mid 90s cars/trucks and it works great. Never a problem hot or cold.
Nov 6, 2008 | 05:48 PM
I have both staggered and straight holes. If the PO hasnt changed the flywheel, how many teeth should it have? What years is the mini starter used?
Nov 6, 2008 | 10:39 PM
Mini starter is used on C4s, 88 up I believe. 95-97 (as applicable) B-body and F-body with 5.7L LT1. Also trucks and Suburbans, at least 4wd 90-99.
Nov 6, 2008 | 11:02 PM
[QUOTE=Durango_Boy;1567743692]The late model truck starters, are high torque and mini.
can you be more specific about year make model vehicles with mini starters that will work with our C3 vettes.
Nov 7, 2008 | 08:31 AM
Oldguard 7
Mark listed them above, they were the ones I was referring to.
Nov 7, 2008 | 11:11 PM
markdtn
So just to be sure, the F-bodies use the same number of teeth on the flywheel? Sorry I'm a little slow tonight.
Nov 7, 2008 | 11:27 PM
My Powermaster hi torque starter has given me great service. Had it for 8 years.
