valve adjustment
Old Nov 6, 2008 | 01:40 PM
palazzopl's Avatar
palazzopl
Default valve adjustment
any short cuts to adjust hydrualic lifters
Old Nov 6, 2008 | 01:47 PM
GTR1999's Avatar
GTR1999
There are several ways to do it, I like the procedure Lars wrote up years ago. Start with #1 cyl at TDC adjust them and follow the firing order by moving the crank in 90* increments. Mark the balancer with caulk so you know where you have to stop when turning.
Old Nov 6, 2008 | 01:48 PM
billla's Avatar
billla
St. Jude Donor '14
There is some level of debate regarding this technique, but for the last 5 years or so I've been using the companion cylinder method and it's been fast and perfect. It does require a VERIFIED TDC indicator.
http://www.carcraft.com/howto/ccrp_0...aft/index.html
jakesindy's Avatar
jakesindy
Default short cut
Do you have a service manual it tells how to buy only turning eng over 360 once I will try to post it tomorrow
Old Nov 6, 2008 | 02:10 PM
1Fordman's Avatar
1Fordman
I have used this method for many years on the other 427 and it was foolproof. Once true TDC was known the balancer was marked every 90 degrees.
Old Nov 6, 2008 | 02:18 PM
billla's Avatar
billla
St. Jude Donor '14
This is the companion cylinder method I referenced in my post.
Old Nov 6, 2008 | 03:15 PM
LB66383's Avatar
LB66383
With #1 at TDC on the compression stroke, adjust:
exhaust valves on #1, #3, #4, and #8.
intake valves on #1, #2, #5, and #7.
Turn the crank 360* so #6 is at TDC on the compression stroke, and adjust:
exhaust valves on #2, #5, #6, and #7.
intake valves on #3, #4, #6, and #8.
Old Nov 6, 2008 | 09:27 PM
rponfick's Avatar
rponfick
I like the method whereby the motor is running and oil is squirting in eight narrow streams over the fenders. That's the method I just used on my '73 BB. Since I had installed Comp Cams Magnum roller rockers, the standard clip on squirter stoppers didn't stay on the rocker arms. Now, I notice in the catalogs for these parts that they say they only work on stock rocker arms. Now, they tell me. I think I only used about a quart of oil for each cylinder bank, and then cleaned everything up for days.
This is my preferred method.
Ralph.
Old Nov 6, 2008 | 09:28 PM
TimAT's Avatar
TimAT
Little messy, but do them running. Back off one at a time until it rattles, tighten it up until it just quits, then go another 1/4 turn. do one side at time and it's less messy unless you're really fast, and park in the grass so you don't oil the driveway.
The GM service manual has a procedure to set them without it running, (I think it's the one LB66383 posted), but it really takes a "feel" to get it right, and you'll be leaving some performance on the table.
Old Nov 6, 2008 | 10:05 PM
Ironcross's Avatar
Ironcross
Its been a while,
.. If I recall correctly, as the {exhaust} starts to {open} adjust the {intake} and as the {intake} {closes} adjust the {exhaust}.
EOI and ICE.
Old Nov 6, 2008 | 10:55 PM
chvet73's Avatar
chvet73
I learned to adjust them in 1970 on a Chevelle with the engine running. Never did it any other way. Can be messy but it sure works well.
Old Nov 6, 2008 | 11:05 PM
PETE 79's Avatar
PETE 79
Use a dial indicator and set your lifter preload at .020"to .025" takes longer to do but its done right.
Old Nov 7, 2008 | 12:20 AM
boat196's Avatar
boat196
Another article
http://www.centuryperformance.com/ad...h-spg-149.html
Old Nov 7, 2008 | 02:48 AM
1hotrod's Avatar
1hotrod
I was about to do the same for my 72, and I am still a bit conflicted about which technique is the best.
My Dad, and friends who are ASE certified like and was taught adjust hydraulic valves hot, and while the engine is running. They either used these oil clips that attach to the rocker arms or a chopped up valve cover.
I was originally going to do it hot with the engine on, but the oil clips that my Dad had only fits stock rocker arms and I have 1.52 Comp cam roller rockers.
So, after doing some research, I founds Lars document, and the one from Comp Cams recommend doing it cold. My friends also warned me about adjusting cold, because if I do it wrong I can flatten my cams
But after seeing this video on Youtube, I feel more comfortable do the valve job myself.
http://www.youtube.com/watch?v=89o5rLpbCgI
Old Nov 7, 2008 | 08:37 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
I've done them engine running and stopped , ether way is easy nobody mentioned a cut out valve cover to adjust them , that way you can take your time and no mess , just have the idle turned down a little . Ron
Old Nov 7, 2008 | 10:33 AM
rponfick's Avatar
rponfick
The cut down valve cover only works if you have low oil pressure and the oil just dribbles out the rocker holes. Mine squirted over the fenders, and I was using a cut out valve cover. I finally trimmed the stock clip-on deflectors so they would fit on the comp cams rockers. After that episode, I see Northern Auto sells a different version that plugs into the oil hole and temporarily stops the flow. At least that is what they are supposed to do since I haven't tried them yet.
Ralph
Old Nov 7, 2008 | 11:54 AM
FB007's Avatar
FB007
Ralph
I use a cut out cover. 40 PSI hot, no shooting oil. Try smaller holes. All you need is room for a socket.
Old Nov 7, 2008 | 01:55 PM
palazzopl's Avatar
palazzopl
I did like the manual said cold with the engine on number 1 tdc then 6 tdc its running and its and its not tapping Thanks for all the Help
To valve adjustment
