muncie 4 speed
Old Nov 6, 2008 | 08:56 PM
fugawi's Avatar
fugawi
Default muncie 4 speed
how many quarts of gear oil do i need. changing to royal purple..
Old Nov 6, 2008 | 09:15 PM
A88FXRS's Avatar
A88FXRS
Fill it even with the hole for the filler plug.
Old Nov 6, 2008 | 09:52 PM
birdsmith's Avatar
birdsmith
If I remember correctly it's two quarts or approx. $100.00 worth of Royal Purple gear oil....
Old Nov 6, 2008 | 11:35 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Most would recomend a conventional lube for your Muncie. Valvoline 80w-90 has an MT-1 sub-spec said to good for the yellow parts,..synchros, etc. Plus, it's no secret a syn will leak before a conventional/mineral lube.
FWIW
Old Nov 7, 2008 | 02:30 PM
DIP51's Avatar
DIP51
2018 C2 of Year Winner
FWIW
Stick with Dino!!!!!
Old Nov 7, 2008 | 02:40 PM
stingr69's Avatar
stingr69
I think I have some left over from when I tried it. You can have it for the cost of postage if you want it.
The tranny made a little more noise after I switched to the Royal Purple and it leaked more. I drained it out, changed the output shaft seal and put some straight 90wt GL-4 rated lube in it. I will not try that synthetic lube again in a Muncie. That synthetic gear oil is supposed to be bad for the old school brass blocker rings so why jack with it?
-Mark.
Old Nov 7, 2008 | 04:03 PM
moosie982's Avatar
moosie982
-Mark.
Would that be the same for a freshly rebuilt B-W ST10 ? Peace,,,Moosie
Old Nov 7, 2008 | 05:27 PM
fugawi's Avatar
fugawi
i sence a patern in the force. dino it is!!!
Old Nov 7, 2008 | 06:06 PM
markey mark's Avatar
markey mark
little less than 2 qts. of the 80-90 stuff. Fill it to about 1/2 inch below the plug. Use a pipe cleaner or a q-tip as a dip stick and you can get it pretty much where it supposed to be, we're not talkin' space shuttle here.
Old Nov 10, 2008 | 05:44 PM
jb78L-82's Avatar
jb78L-82
Sorry guys but Mobil 1 gear oil in my 4 spd for 20 years! No leaks and much easier shifting when cold! Synthetic oil is dino oil that is reformulated so that all the molecules are the sames size with a more robust additive package. I have run Mobil 1 15W-50 Racing in the engine and in the differential as well since 1985 with zero issues and no leaks.
Old Nov 11, 2008 | 12:09 AM
73, Dark Blue 454
Give George Sollish a call. He's the chief engineer at Autogear which is selling the new beefed up Muncies. Ask him what he thinks of synthetics and Muncie transmissions:
www.autogear.net
To muncie 4 speed
