Rear-End Ideas?
Old Nov 11, 2008 | 01:35 PM
Glensgages's Avatar
Glensgages
Originally Posted by Hybrid117
My vette is a 80 L82, It will be drag raced but will be street driven also.
I want my rear-end to be strong enough that i never have to worry about it.
Talk to some of the guys who are running Stock or Super Stock eliminator (vetteman9369), or
http://forums.corvetteforum.com/c3-t...lly-needs.html
Old Nov 11, 2008 | 02:06 PM
GTR1999's Avatar
GTR1999
Originally Posted by 63mako
I bought a Tom's setup within the last 6 months. Still available on their website. They have been doing this since the 70's.
http://www.tomsdifferentials.com/catalog.asp?pg=22
Tom stopped building about 5-6 weeks ago.
Old Nov 11, 2008 | 09:33 PM
brngrhd's Avatar
brngrhd
here is the best way to make sure it will not ever break........ easy install and great guys to work with.
http://forums.corvetteforum.com/c3-t...olid-axle.html
http://autofabcart.net/1968-1982corv...4-linkkit.aspx
Old Nov 11, 2008 | 10:18 PM
Street Shaker's Avatar
Street Shaker
Toms main guy that use to assemble these rear ends (Kenny passed away few months ago, and Tom doesnt have anyone to assemble them any more, so he's most likely just retiring. He is still supplying parts, but no assembly.
One of the differential shops that worked with him in building these same rear ends and supplying parts from Tom is in business doing a pretty good job at it, good people Tom referred me to them, they did a gear swap for me.
Perfect Pattern Differentials
1517 E. Rosewood Ave
Spokane WA 99217
Steve Witting
509-487-4797
Old Nov 12, 2008 | 02:03 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Does anyone know if Pepe Estrada (father of the 12-bolt IRS) is still around? He had been working with Henry's Machine Works (who did mine) prior to Tom's "hiring" him way back when they first got serious about building these.
In any event, Gary, it looks like you've timed getting into doing the 12-bolts very well.
Old Nov 12, 2008 | 05:42 PM
GTR1999's Avatar
GTR1999
Ah Pepe, I was sure it was Tom who worked for him then bought him out. I have an article about him building these going back to '75. Tom has refined the process since then in some areas. I asked Tom what ever happened to him once but no one knew?
I spoke to Steve today @ PPD. Nice guy, knows and uses some of Tom's parts in vette diffs, builds diffs for all makes, not vette specific, does a lot of muscle cars. Said he doesn't get involved in the T/A's or other vette units.
When was the last time Henry's built one, any idea? I have made some minor changes with the way I'm building them as well.
Old Nov 12, 2008 | 07:25 PM
TheSkunkWorks
...When was the last time Henry's built one, any idea? I have made some minor changes with the way I'm building them as well.
What details I'm aware of being sketchy, at best, that's why I put quotations around "hiring"...
Haven't kept up with Henry's since they did mine back in the day, but they remain in business. However, for whatever reason I can't navigate their site and haven't persisted to reach them via phone, so I don't know what all they still do. Their ability to perform the necessary processes in-house to produce HD 12-bolt ring & pinion sets taller (smaller ratios) than 3.73:1 was a primary reason I went with them for my 3.55:1.
BTW, I had been under the impressions that the 10-bolt 71-79 iron housing could be mated to the 80-82 batwing with some work, but that there wasn't enough meat in the batwing's diff cover area for the larger 12-bolt chunk and ring. Am I mistaken and, if so, could you clear that up for me and anyone else reading along?
Here's hoping this all doesn't constitute a hijack.
edit - The C3/D44 batwing can be adapted to accept a 12-bolt IRS diff with a spacer/mid-plate to make up for lack of material.
Old Nov 12, 2008 | 11:58 PM
Hybrid117's Avatar
Hybrid117
no its cool i need the most info and routes i can get
Old Nov 13, 2008 | 12:13 AM
Hybrid117's Avatar
Hybrid117
I like it! So thats just the conversion for the soild axle, i would have to buy everything else separately? How much did you spend total on that rear and estimate on time?
Old Nov 13, 2008 | 11:40 PM
brngrhd's Avatar
brngrhd
i spent $4300 that was everything from autofab...... strange fab nine upgraded center to the S housing upgraded locker 35 spline axles QA1 coil overs wilwood brakes with parking brake and the 4 link stuff....... they said it will handle 1200hp...... time well if it all comes apart easy i bet you could have it all done in a long weekend or two at the most.
Old Nov 14, 2008 | 01:44 AM
Hybrid117's Avatar
Hybrid117
ok cool, ya i dont think i would need the wilwood brakes or some other things so that doesnt seem like a bad price, i guess i need to start saving more lol
Old Nov 14, 2008 | 08:41 AM
GTR1999's Avatar
GTR1999
SW- excellant point on the 12B with the 80-82cover, this may be a problem. The std iron cover has to be ground inside for clearance as well so that could be an issue with the alum. I'll check into and see. For a 10 bolt conversion no problem. The only ratios I can get for the 12B are 373,411,456. 355 would be nice but I suspect Tom didn't get much call for them so they would have to be machined like they did years ago on a 1/1 basis and then the labor skyrockets. I dont' have a 80-82 cover here to check it as I don't work on those diff's.
I'll PM you some info I found out on these too for your info.
Old Nov 14, 2008 | 10:24 PM
  #33
427midyear's Avatar
427midyear
Cruising
Crazy! I spoke to Kenny like 4 or 5 times in the last year. The last time being 3 or four months ago. Lots of knowledge lost there.
When I spoke to Kenny about higher gear ratios, their reasoning for not doing them was that with the increased size in the pinion gear head it moves the crown of the ring gear over towards the drivers side. In clearancing the case for 3.55 and numerically lower ring gears, it makes the case substantially weaker. Even with the 3.73 and numerically higher gear ratios, he said that you want to remove as little material as possible to retain structural strength. He said that people asked all the time for higher ratios. I ended up getting a 3.73 12 bolt.
