Need advise please???
Old Nov 11, 2008 | 08:29 PM
mikecc's Avatar
mikecc
Default Need advise please???
Hello guys,
Looking for some advise.. My 1978 L-48 350 mainly stock with an edelbrock carb and manifold was running weird.. what I mean is from a dead stop if I pushed hard into the gas it would bog down and act gas starved.. well I adjusted the two screws on the front and leaned it out... idles a little lower and seems to not bog down as much but I still have some issues there with it bogging down... any advise on this guys???
Old Nov 11, 2008 | 09:27 PM
duntovlives's Avatar
duntovlives
sounds like you maybe running outta gas. checked your filter?
Old Nov 12, 2008 | 12:11 AM
mikecc's Avatar
mikecc
new filter yes.....
Old Nov 12, 2008 | 12:27 AM
RockyL32's Avatar
RockyL32
From: If your not the lead dog the view never changes Boise, Id
Take off the air cleaner. With the engine running block some of the carb with your hand. If it runs better you have a vacume leak
Old Nov 12, 2008 | 12:49 AM
Peterbuilt's Avatar
Peterbuilt
Have you looked at the accelerator pump or the linkage? PG.
Old Nov 12, 2008 | 02:46 PM
gerry72's Avatar
gerry72
If it was gas starved, you would experience a lean backfire through the carb along with the bog. You can also bog from an overly rich condition. Here, you get the bog but no backfire. It can also be timing related. Check timing and experiment with your accelerator pump shot.
To Need advise please???
