Power steering woes
Old Nov 12, 2008 | 10:40 AM
nw2571's Avatar
nw2571
Default Power steering woes
Got the car washed and waxed the other day, changed the power window relay so I could roll them down, and got all psyched about the last Vette ride before winter when the power steering went out.
I suspect the pump, so I went ahead and pulled it to inspect (it has been leaking anyway). Once I got it off I noticed that nothing really looks wrong. Any good way to check the functionality of the pump itself once it's off the car? What about a diagram of the internals to look at?
Thanks!
Old Nov 12, 2008 | 06:41 PM
Mikey74Stingray's Avatar
Mikey74Stingray
Well I have no idea but I'm replacing mine right now. just got the new pulley in the mail today!
any tips on bleeding the PS system?
Old Nov 12, 2008 | 07:54 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Fill the Resevoir and then get the front wheels off the ground. Start the car and move the steering wheel from lock to lock 2 or 3 times. Don't let go of it at all or it will take off on you. Bring the front end back down and top of the resevoir. Take it for a drive and then check it and top it off again.
Old Nov 13, 2008 | 12:43 AM
Mikey74Stingray
good info! thanks
Old Nov 13, 2008 | 08:26 AM
Jim Shea's Avatar
Jim Shea
You will save some time if you jack up the front end and work the steering system full lock to full lock before starting the engine. Add fluid to the pump reservoir as large bubbles come to the surface of the fluid in the reservoir. You may need to rotate your steering wheel full lock to full lock a couple dozen times. Getting most of the air out before starting the engine prevents the air/oil from being whipped to a froth as air passes through the pump. This will cause your fluid to like milky with millions of tiny bubbles entrapped in the fluid. The air will eventually work its way out of the fluid (but it might take a day or two).
BTW, genuine GM power steering fluid (available at GM dealers) seems to be better than most aftermarket fluids at helping to expel air from the system.
Jim
Old Nov 13, 2008 | 11:26 AM
68/70Vette's Avatar
68/70Vette
Jim
Another thing about auto store PS brake fluid. When I when to buy fluid for my all new and all dry power steering system, I went to a local auto store and looked at the various brands of PS fluid. They all advertised, in various different words, that they had leak preventative additives. This meant to me that they were all formulated for used and worn PS systems. I thought that whatever the additive was, it probably wouldn't be in GM PS fluid that was designed (I would guess) for new PS systems. Therefore....a trip to the local GM dealer for genuine GM PS fluid.
To Power steering woes
