bad u joints?
Old Nov 13, 2008 | 11:52 PM
RONZ-C-3's Avatar
RONZ-C-3
Cruising
Default bad u joints?
I have replaced my u joints twice on the left side I seem to get about 150 to 200 miles till they start making noise one set I could see being bad but two? any ideas?
thanks
Ron
Old Nov 14, 2008 | 01:52 AM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
that does sound weird. is it both on the same side? maybe you should replace them and swap halfshafts from one side to the other. if the problem goes to the other side, i'd suspect a halfshaft (maybe out of balance?).
Old Nov 14, 2008 | 09:02 AM
wombvette's Avatar
wombvette
Thats a weird one. I dont think balance would cause that much damage in that short of time. I would look for a bent shaft, bent components, or binding parts. Somethings really out of sorts.
Old Nov 14, 2008 | 09:10 AM
rj8806's Avatar
rj8806
Have you changed anything in the driveline? Say a tranny or rear end housing? If the driveline angles were out of whack that would cause pre-mature wearing of the u-joints.
Richard
Tech Support
Old Nov 14, 2008 | 11:32 AM
Vampyre's Avatar
Vampyre
How is the rear camber, if the tires look like this from the rear / \ you should adjust them to look like | |
Old Nov 14, 2008 | 05:34 PM
sjr1971's Avatar
sjr1971
thanks
Ron
My guess is the shock on the left side. The universals are captured. If the wheel is off the ground the uni's can't make a full turn.
To bad u joints?
