O.E. Fuelpump
Old Nov 15, 2008 | 07:56 AM
sevnty7's Avatar
sevnty7
4th Gear
Default O.E. Fuelpump
I have just installed a edlebrock 2101 manifold & a 1406 carb on my 77 stock l-48. is the stock pump to much pressure for this setup? just wondering what you other folks are running for a mechanical pump out there. will edlebrocks pump work with our cars having a return line at the pump? ........Thanks
Old Nov 15, 2008 | 08:24 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I ran my 70 on an Edelbrock fuel pump without a return for several years like that with no problem.
Old Nov 16, 2008 | 10:09 AM
palazzopl's Avatar
palazzopl
try a fuel pressure regulator and keep the pressure under 6 psi. Go to edelbrock.com and it will tell you about the pressure
Old Nov 16, 2008 | 11:37 AM
billla's Avatar
billla
St. Jude Donor '14
Stock is up to about 7 PSI; just ensure your Edelbrock pump doesn't require a regulator.
Old Nov 16, 2008 | 01:05 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Q-jets are as sensitive about fuel pressure as any carb out there.
I doubt that you will have any problem sticking with the stock pump.
Old Nov 16, 2008 | 01:12 PM
spikebot 81's Avatar
spikebot 81
I have the same set up as you with stock gm fuel pump with return line. No issues, no stumbles, runs great
Old Nov 17, 2008 | 04:41 AM
c31980's Avatar
c31980
same here ,,stock pump work fine
To O.E. Fuelpump
