Guys i need to know what the original pump is called,and can i run a saginaw power steering pump,the flatter pump,mine is rounded at the bottom.I dont know if my pump is called a saginaw pump or something else.its a original power steering pump from a 69 vette.
Get a kit and reseal it. No big deal. Off the car, take out the outlet fitting and the bolt/stud and the pump will come out of the reservoir. Big Oring seal and a couple of Orings on the back. Easy fix. shaft seal is a little more difficult, but still doable.
If you do swap pumps, thnk about taking the outlet fitting/pressure regulator from the original and put it in the new one. I recall seeing something about Vettes having a different one than other cars. Maybe not. Might be worth doing a little research.
Tim,i take it that both styles of pumps will fit?I can get a chrome one at a good price.But first i wanted to make sure that the other type would work and bolt up the same.The studs on the back of both pumps looks to be the same.Also my pump has a bad front seal.Bill
