Disc Rotor Runout
Old Nov 19, 2008 | 07:54 PM
ksbunting's Avatar
ksbunting
Default Disc Rotor Runout
Tried unsuccessfully to post this in Off Topic.
How does one determine what is acceptable disc rotor runout; how many thousandths is acceptable?
I purchased a dial runout gauge and would like to use it but don't know how much runout is OK and how much is bad?
Where does one find such specs?
Thank you,
Kurt
Old Nov 19, 2008 | 07:59 PM
Gordonm's Avatar
Gordonm
I try to get .005 or less. I have all 4 of mine at or under .003. Anything over .010 I would not run and will probably pump air into the system.
Old Nov 19, 2008 | 09:16 PM
ksbunting's Avatar
ksbunting
Gordonm,
Thank you.
Is this a standard rule of thumb or does it vary for vehicles?
Would this be the same tolerance for my minivan or my wife's Audi, in other words for all rotors for all cars or is there some place to find specific tolerances by vehicle manufacturer?
Old Nov 19, 2008 | 10:04 PM
Gordonm's Avatar
Gordonm
This is for the Vettes. Due to the type of caliper used this is the tolerance. Other cars can go way more and not pump air into the system.
Old Nov 19, 2008 | 11:26 PM
Speed Direct's Avatar
Speed Direct
Premium Supporting Vendor
According to the factory service manual total runout should not exceed .002" but that is with the wheel bearings snugged so there is no play. You wouldn't drive it with the bearings set like that but that is what the shop manual says for checking the runout. This measurement is for non-floating calipers. There is a bit more leeway for floating calipers.
Old Nov 20, 2008 | 01:10 PM
GTR1999's Avatar
GTR1999
Keep the runout under 005 and you should be ok as long as the brg endplay is also in spec.
I set endplay for 0015 and the runout under 003", brakes stop on a dime.
Old Nov 20, 2008 | 05:58 PM
Mike Ward's Avatar
Mike Ward
No, rotor runout is not critical on cars with floating calipers.
If you can't feel vibration in the brake pedal or shaking in the steering wheel, don't worry about it.
Old Nov 20, 2008 | 07:45 PM
dennis's Avatar
dennis
Thank you,
Kurt
install oring seals and you can forget the air pumping
Old Nov 20, 2008 | 07:53 PM
'75's Avatar
'75
At .015" runout I wasn't pumping air but I was getting an annoying squeak, squeak, squeak. I shimmed them to .002 and under and they quieted right down.
Old Nov 20, 2008 | 08:19 PM
mrvette's Avatar
mrvette
Gary is totally correct, of course, FOR A FACTORY STOCK SYSTEM but if you redoing brakes and want to get to a good stable end result without any messing around, do it once and forgetaboutit....do this.....
Stainless calipers filled with O ring pistons stockish pads....
make sure the rear hubs are well within specs...very snug...
front too, for that matter...new rubber and maybe steel lines....
fresh master cylinder....and watch for anything even remotely looking like a leak out of that proportioning valve..be very aware, it's a sneaky SOB out of that light switch in that brass block....the the final modification that stands your shark on the nose every time and makes the pedal solid as a rock....
HYDROBOOST apparently the best/easiest is from a Astro van....THAT is the final thing I did to finally fix my brakes after covering all the other bases.....brakes that WORK, and any vacuum assist stockish boosters are CRAP, and that is across the lines from any car/maker....
Old Nov 20, 2008 | 08:25 PM
kdf1986's Avatar
kdf1986
For adjusting the run out on the rotors, what type of material is used, and where is it placed. Between the studs and rotor would be my guess.
kdf
Old Nov 20, 2008 | 09:35 PM
'75's Avatar
'75
I used some shim stock and siccors and cut out some "washers" and sandwiched them between the rotor and hub. I also painted 1 of the studs and the corresponding hole in the rotor so I would know the orientation if I remove the rotor.
Old Nov 20, 2008 | 10:23 PM
ksbunting's Avatar
ksbunting
Gary,
At the risk of sounding dumb, how do I measure/set the end play of the bearing?
I always just tightened them by hand until they were snug and the cotter pin hole lined up
Kurt
Old Nov 21, 2008 | 08:21 AM
GTR1999's Avatar
GTR1999
Gary,
Kurt
Not a dumb question Kurt, look up my threads on the bearings. There are a lot of pictures. I don't post them here anymore because people complain and they're removed. Look on the other forums under my name and you'll find them or on Barry K's site.
The rear require rebuilding and machine work, the fronts may just need to dress the nut.
To Disc Rotor Runout
