water on the car floor
Old Nov 21, 2008 | 11:57 PM
raulotero91's Avatar
raulotero91
Default water on the car floor
Hey guys i need your help. One day, i noticed that after it rains, the carpet would be wet. I removed the carpet to see if there would be any trace of were the water would come from but i couldn't see any clues. I know that it isn't coming from the ttops. I have heard that it might becoming from the window seal? Does anyone know how I can be sure where the water is coming from and how can i fix it?
any feedback would be helpful
Old Nov 22, 2008 | 01:06 AM
wombvette's Avatar
wombvette
Leave the carpet out and leave the car out in the rain. You should see it.
Old Nov 22, 2008 | 01:07 AM
TimAT's Avatar
TimAT
Couple of tricks. One is to run a hose over the suspect area and look for tracks. another way is to close the car up tight, turn the heater blower on high and spray the window seals, tops and cowl with soapy water. If it blows bubbles you found the leak.
Old Nov 22, 2008 | 01:11 AM
70Yellowbird's Avatar
70Yellowbird
Remove your kick panels ... then look through the air damper openings and see if there is water inside and if they are plugged with debris.
Old Nov 22, 2008 | 10:07 AM
Durango_Boy's Avatar
Durango_Boy
A rotten windshield frame will yield water down the firewall, soaking the carpets on either side, or both.
To water on the car floor
