coild spring ID
Old Nov 24, 2008 | 09:08 PM
sonny_burnett's Avatar
sonny_burnett
Default coild spring ID
My car looks a little low in the front end, it came with some parts in boxes including a new set of coil springs for the front end. How can I tell what these springs are without a spring testing machine? The stock springs were 293 lb/in and the f-41 was 550 lb/in, so I would think the free length of the f-41 would be noticeably less, but I can't find these numbers anywhere. Is the wire diameter different? Does anyone have the free length and wire diameter number for the 239 and 550 lb/in springs? Thanks.
Old Nov 24, 2008 | 09:30 PM
dannyman's Avatar
dannyman
Good question!
A little more information will yield results, I'm sure.
What year?
Small block or big block?
I'd like to know the diameter of the coil material myself for future reference.
Old Nov 24, 2008 | 11:09 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Most aftermarket springs are eithere 460's or 550's.
460# Springs are 13" in free length and are considered small block springs.
550# Springs are 12" in free length and are considered BB Springs.
Hope this helps.
Van Steel's Avatar
Van Steel
Most aftermarket springs are either 460's or 550's.
Hope this helps.
Old Nov 25, 2008 | 10:52 PM
sonny_burnett
Thanks Van Steel
To coild spring ID
