tap drive extension?
Old Nov 27, 2008 | 02:06 PM
jnb5101's Avatar
jnb5101
Default tap drive extension?
what do you guys use to extend the reach of tap sets when the t-handles won't reach?
Old Nov 27, 2008 | 02:46 PM
glassman74's Avatar
glassman74
JNB,
Use a 12 point socket that will fit the tap end.
glassman74
Old Nov 27, 2008 | 04:46 PM
RobSarge's Avatar
RobSarge
6th Gear
..a metric12-point socket works better, seems to be a tighter fit and gives better feel when tapping and reversing to break the chips.
Old Nov 27, 2008 | 06:56 PM
imariver's Avatar
imariver
McMaster Carr actually sells tap extensions. I have several of them and they work great.
Old Nov 27, 2008 | 07:33 PM
'75's Avatar
'75
All of the major tool makers sell tap sockets. You can then use a regular 3/8 or 1/4" extension and ratchet.
Old Nov 27, 2008 | 11:19 PM
chvet73's Avatar
chvet73
I have a Craftsman tap & die set. Fairly old set. The T-handle slides out of the holder. Then the top is a square hole. That square hole is for any 3/8" drive ratchet or extension. I had the thing for years before I realized that's what the square hole was for. If yours has it, then try it otherwise go with the extension ideas.
To tap drive extension?
