Wiper Door
Old Nov 28, 2008 | 10:17 PM
1jrgs68's Avatar
1jrgs68
5th Gear
Default Wiper Door
Can anyone tell me why the wiper door on my 68 is in the open position, even when the wipers are off? The override **** is not in the on position. That was the first thing I checked.
Old Nov 28, 2008 | 10:45 PM
baxsom's Avatar
baxsom
it uses vacuum to open and close.
chances are the relay that switches where the vacuum goes is bad.
or there is a hole in the vacuum line that closes it.
Old Nov 29, 2008 | 05:21 AM
WESCH's Avatar
WESCH
Hi
Wiggle the wiper switch a bit. I had the same problem and found that the wiper somehow did not park correctly and keeping the door open.
Rgds. Günther
Old Nov 29, 2008 | 08:32 AM
Alan 71's Avatar
Alan 71
Hi 68,
Do 68's have the vacuum valve under the right side wiper arm in the wiper well? If they do it needs to be closed by the right side wiper arm coming down into the park position and signaling that it's O.K. for the actuator to close the door.
I'm sorry I'm not sure if 68's have this valve or not.
Regards,
Alan
Old Nov 29, 2008 | 10:39 AM
avner's Avatar
avner
Originally Posted by Alan 71
Hi 68,
Regards,
Alan
On 68 (early) you don't have the vacuum valve under the right side wiper arm in the wiper well.
Avner
Old Nov 29, 2008 | 11:30 AM
...Roger...'s Avatar
...Roger...
Try applying vacuum to the small port on the wiper door relay and see if the door comes down.
Old Nov 30, 2008 | 05:17 PM
1jrgs68's Avatar
1jrgs68
5th Gear
Thanks for all your help!
Old Dec 1, 2008 | 01:08 PM
john roth's Avatar
john roth
Hi 68,
Regards,
Alan
Cool I was going to ask that question, I thought somthing was amiss because it was so tight to the wiper base ( DUMMY). Is there a way to "TEST" the actuator that moves the whole contraption ?
JR
Old Dec 1, 2008 | 08:48 PM
rthawk1's Avatar
rthawk1
Default thanks
I am having the same problem as well. After the vette comes back from the paint booth I will try to work this oout as well.....thanks for the info.
rt
To Wiper Door
