What is this part?
Old Nov 29, 2008 | 01:56 PM
joewill's Avatar
joewill
Default What is this part?
On my '70....It is behind the license plate.. I can't find it in the AIM? I think there are 2 of them and one is missing on my car?
Old Nov 29, 2008 | 02:21 PM
...Roger...'s Avatar
...Roger...
I should know this because I just put a tank in a 70 a couple weeks ago.The bracket looks familiar just not in that location.
Old Nov 29, 2008 | 02:30 PM
joewill's Avatar
joewill
all it does is just hang there, nothing to connect it to? It does have a slide connection to whatever it connects to for adjustment.....
Old Nov 29, 2008 | 02:50 PM
BHRIG's Avatar
BHRIG
Default What is it?
Hey, Guy!
I think that part might be from the spare tire carrier.
It looks like the assembly that held the lock......
Just a guess... I hope I'm right and it solves your problem
Old Nov 29, 2008 | 03:29 PM
Jeffsvettes's Avatar
Jeffsvettes
Hi
That bracket should be bent back to the rear valance panel behind the license plate where you have the rusted nut below the license plate mounting nuts.The bracket should have a nut attached to it instead of the rusted ones.There should be one on each side.
Jeff
Old Nov 29, 2008 | 03:33 PM
...Roger...
Originally Posted by Jeffsvettes
Hi
Jeff
Look in section 7 rearend and deck.They're there but a diff shape.
edit-I think in that shape they look the brackets under the frt floorboards that hold the heat shields.
Old Nov 29, 2008 | 03:46 PM
avner's Avatar
avner
Hi
Jeff
Old Nov 29, 2008 | 04:08 PM
FrankVincent's Avatar
FrankVincent
Account disabled by user request 5 Jan 09
Originally Posted by joewill
On my '70
That is the rear filler panel bracket (yes, should be 2 of them)
It has been bent way out-of-shape ...
See Corvette Central item #203111
http://www.parts123.com/parts123/yb....Z5Z5Z50000050G
in my 1968 AIM, it's located under UPC1, F21 ... your '70 AIM should be right around there I suspect ..
Old Nov 29, 2008 | 04:52 PM
69small block's Avatar
69small block
Originally Posted by avner
Old Nov 30, 2008 | 10:20 AM
joewill's Avatar
joewill
excellent gentlemen!!... thanks... maybe mine is just reversed..
-Joe
Old Nov 30, 2008 | 11:06 AM
...Roger...
-Joe
It looks like someone just bent them towards the front of the car.
Old Nov 30, 2008 | 02:17 PM
VetteLS6's Avatar
VetteLS6
Wasnt that the "Side stabilizer bracket" for the optional Class III Hitch?
To What is this part?
