Speedometer Calibration question (again)
Input parameters are the following:
* Speedometer Revolutions/mile = 1000
* Rear Tire Diameter (Inches) = 27.10
* Differential Gear Ratio = 3.07
* Drive Gear Teeth Number = 14
Computation Results:
# computed Driven Gear is 32
# Ratio of driven over Drive Gear is 2.3
I am not sure this is right because nowhere it asked me to enter the actual speedometer( maximum speed indicated). Can someone please indicate to me what I don't get right?
We can calibrate the speedo for you if you want, but it’s not necessary and to be honest 150.00 to calibrate a speedometer is way steep (IMHO)! We've been doing them in house for over thirty years and 150.00 is. . . Well again way too steep!
We check them for free, and if calibration is needed it’s only 35.00. It only takes about 15 minutes to check and calibrate a speedometer that is defect free! If there is problem in the speedo we will contact you before we do anything.
Now if the original speedometer is off there is no reason to re-calibrate the 140 speedometer. The 140 speedo will already be calibrated to the input of the speedo cable.
Willcox!
Thank you all for your responses. The first thing I did when I got the 140 speedo was to installed and try it. The reading I got was erratic i.e. the needle was "crazy". The 140 speedo come a 1977 Vette and it has only 43,000 km on it. I think that the speedo cable is fine sine it gives me the right reading with the 90 MPH speedo. I did multiples searches in the various forums and I came to the conclusion ( maybe the wrong ones :-)) that it was something with the the number of teeths on the driven gear in the transmission.
Should not require any recalibration at all.
