Tire noise
Old Dec 2, 2008 | 01:54 PM
ANY VETTE's Avatar
ANY VETTE
Default Tire noise
I am a new 76 owner and hear a rumbling noise sounding like it is coming from the back tires.These are not stock and are wider on Cheviot rims. Now not knowing what a C3 sounds like can you hear your tires a fair bit or is this a sign of serious problems.It sounds like I am running over a million tiny speeed bumps?
Old Dec 2, 2008 | 02:06 PM
7T1vette's Avatar
7T1vette
Different tires and different tread designs will produce different sounds. Some tires are designed to run quieter...at the expense of poorer performance [usually]. Other possibilities are that one [or more] wheels are out of alignment or there is a wheel bearing starting to fail (or running dry). C3's are NOT quiet cars. Many owners put sound absorbing materials under the carpeting to reduce 'road' noise.
Old Dec 2, 2008 | 03:14 PM
hugie82's Avatar
hugie82
Try throughing another tire (spare tire maybe) on the driver side rear. If the sound changes then its the tires. If not, a bearing maybe going. My 75 had road noise, then I installed a real exhaust never heard it again.
Old Dec 2, 2008 | 03:52 PM
ANY VETTE's Avatar
ANY VETTE
I hear this noise even though the cats are removed and I have headers..?
Old Dec 2, 2008 | 05:21 PM
hugie82's Avatar
hugie82
If your muffelers are stock your still running pretty quiet but try the tire swap. If it doesn't change it is most likely a bearing and if it is, you want to fix it now rather than later$$$
Old Feb 11, 2009 | 08:13 AM
ANY VETTE's Avatar
ANY VETTE
Just an update that this was indeed my rear bearings although when spun the tire by hand I didn't hear any grinding what so ever.
To Tire noise
