C3 Rear Spring Installation
Old Dec 2, 2008 | 02:01 PM
Raptor119's Avatar
Raptor119
Default C3 Rear Spring Installation
I'm new to this forum so please bear with me....
I have a 68 convertible that I need to swap out frames. I have an excellent replacment frame. I want to build the suspension (front and rear) and driveline and then do a body removal and drop onto the replacement frame/suspension.
My question: I am looking for how you can compress a rear spring to install it when you don't have the full weight of the car to assist? How can I easily compress the rear spring and install it?
Looking for any write up and tools I will need. With the force of the compressed spring I am not inclined to cut corners here.
Old Dec 2, 2008 | 02:28 PM
MN-Brent's Avatar
MN-Brent
A lot of guys use a C-clamp on the spring, and then use a hydraulic jack next to the C-clamp so the jack does not move up the spring.
Here is a write up in the Tech Tip section under OTHER heading:
https://www.corvetteforum.com/techti...D=75&TopicID=3
Brent.
Old Dec 2, 2008 | 02:53 PM
Alan 71's Avatar
Alan 71
Hi R,
Here are 2 pictures of the rear spring being installed on my 71's frame.
The first shows 6 boxes of Corvette magazines and a bundle of roof shingles putting some weight on the frame.
The second shows the clamp, wooden blocks, and jack that MN described.
You can do it, just be careful.
Regards,
Alan
Old Dec 2, 2008 | 03:32 PM
hugie82's Avatar
hugie82
you can use a come-along and a pulley. Attached C-A to the opposite frame rail. Run cable through pulley attach to other frame rail side and pull up on that spring side then reverse for otherside.
Old Dec 2, 2008 | 07:48 PM
Raptor119's Avatar
Raptor119
Thanks for all the feedback,
How much do yo have to compress the spring before it will line up with the rear trailing arms? 6 inches? More?
Old Dec 2, 2008 | 08:20 PM
howarsc's Avatar
howarsc
big rachet straps work too. Just wrap around spring and frame and pull together...
Old Dec 3, 2008 | 05:44 PM
Alan 71's Avatar
Alan 71
Hi R,
If you look at my first picture you can see how low the left side of the spring is on my stock/base spring. I'd say it comes up about 8-10 inches before you can catch the stock length bolt and get the nut started. Don't forget the cushion and the large washer under the spring.
Good Luck!
Regards,
Alan
Old Dec 4, 2008 | 01:54 PM
billsfan's Avatar
billsfan
Another trick to line up the trailing arm to the spring is to jack up the trailing arm to match up the holes.
Old Dec 4, 2008 | 02:48 PM
Raptor119's Avatar
Raptor119
Default C2 Rear Spring Installation
Thanks for the feedback and ideas to all!
Old Dec 4, 2008 | 05:57 PM
1nicecorvette's Avatar
1nicecorvette
the jack way is the way i installed my new bushings works perfect. make sure if you want to adjust ride height (if composite) that you get the longer bolts. This too will allow less jacking to meet the threads also
To C3 Rear Spring Installation
