Rear spindles
Old Dec 6, 2008 | 03:38 PM
Gordonm's Avatar
Gordonm
Default Rear spindles
Looking at new rear spindles I have seen many from many vendors. They all say the exact same thing. Drop forged, better quality steel than 40 years ago, stronger, blah blah it is almost identical the verbage they use. The prices range from a low of $99 to as much as $199. These are all stock 17 spline replacement axles. Nothing special. Are they all made from the same manufacter and just priced differently?
Old Dec 6, 2008 | 09:29 PM
GTR1999's Avatar
GTR1999
IF USA made then they're probably from Spencer Forge, there are also imports on the market. Toms sells his own as well, made here in the USA with both 7/16 & 1/2 stud hole, no rivet holes though if you want to bolt on the rotors. Also has the 31 splines. Now that I finished up that 12 bolt diff I'm going to build the T/A's with the 31 spine axles. Watch for the pictures,just not here.
Old Dec 6, 2008 | 09:48 PM
Gordonm's Avatar
Gordonm
Gary,
I know where to find the pictures and the write up
To Rear spindles
