Help
Old Dec 6, 2008 | 11:39 PM
Doug Maitlen's Avatar
Doug Maitlen
Default Help
I know that I have a bone stock 79 L48 with 195 horsepower. I see you all know your gear ratios. Can anyone tell me what gear ratio mine has? Is there any way to tell what size gear ratio is in my 68? I know that it is higher because it was run at the strip. Any feedback would much appreciated.
Thank you
Doug
Old Dec 7, 2008 | 12:14 AM
wombvette's Avatar
wombvette
Thank you
Doug
All rears had codes stamped on the bottom flange. Check that code. You can always fall back on the old turn the driveshaft and count the wheel revolutions method, if you dont think its the original ratio. Count how many revolutions per one turn of the wheel. That is your ratio.
Old Dec 7, 2008 | 06:54 AM
Duke94's Avatar
Duke94
"OM"=3.36
"OH"=3.55
"OJ"=3.70
The code is located on the bottom of the differential carrier housing by the cover.
To Help
