Hi Guys
I'm doing some research on new heads.
Currenly I have the stock 77 L-82 heads with ceramic coated block huggers from Sanderson.
In my Head research I see Rectangular, Square, and Oval exhaust ports.
Will my headers work with all these? I want to use my existing headers.
Also using the Weiand 8004 Alum intake. I want to be sure to be able to reuse that as well.
Get some after market RHS Vortec heads. They are drilled for your intake, and flow amazingly well for the low cost. They have the larger valves, and your exhaust will bolt right up.
