Accelerator pedal (69E) need pics or advice
I have some trouble installing my accelerator cable to the pedal (69E style with separate rod, BB with Q-jet, new original GM accelerator cable). The cable seems to short, connecting the cable to the pedal lifts the bottom of the pedal up from the carpet (about 2,5 inch).
So I would need some pics from the cable to carb bracket mounting and pics of the pedal (shape and mounting of the rod, I suspect Bubba bent the rod).
Any other advice is also welcome!
Thanks!
Dirk
Moral of the story......someone might of bent it outward,cause it bent inward from previous use.Mine was also,up off the floor,but I also,put spacers under the pedal mount to give me more travel.
If you adjust the linkage so that the carb will fully open, you have to be carefull that there isn't much travel left in the pedal or the sheet metal extension on the pedal rod will bend. There is no spring action to take up any additional travel. The only adjustment I can see is the attachment to the throttle shaft, and a little adjustment in the clamp that attaches the cable housing. But, like I said, it is pretty much a solid linkage, and if you have room under the pedal at wot and you put alot of pressure on the pedal, something will bend.
