Timing on '82
Old Jan 17, 2002 | 04:14 PM
JRtex's Avatar
JRtex
Default Timing on '82
I believe that to set the timing correctly on the GMs with the HEI, you are to disconnect a wire in or from the distributor to somewhere. A tan/black or tan/white wire? I don't see anything like that on my distributor. Anyone have any idea of what I should be looking for here?
Thanks,
JR :confused:
Old Jan 17, 2002 | 04:29 PM
1yy07's Avatar
1yy07
Default Re: Timing on '82 (JRtex)
There is a brown wire with a black stripe on it on drivers side of the dist.Hope this helps! :cheers:
Old Jan 18, 2002 | 09:18 AM
terry82's Avatar
terry82
its back there , hard to find the first time.the wire is a tan color, the black stripe is hard to see
Old Jan 18, 2002 | 09:26 AM
JRtex's Avatar
JRtex
I have a tan wire that plugs into the distributor cap, and it goes to the tach. Is that the one? That's the only one I see that looks brown or tan. It this os not the correct one ( and I don't think it is) where does the right one come from in the distributor, and does it unplug at the dist., or inline somewhere?
Thanks for your help,
JR
Old Jan 19, 2002 | 01:56 PM
terry82's Avatar
terry82
no the tach wire is not the right one.on the drivers side of your car look down next to the distributer there is wire harness coming out of the fire wall.that is where the wire is ,it has a black connector in the midile of the wire then goes back in to harness
To Timing on '82
