Have a 69 big block without PB. Replaced mastercyl.,hoses and all 4 calipters (changed to o-ring type) as they were leaking. After bleading ( for a very long time to get rid of all the air) I do now have a good and strong pedal. Taking the car for a testride-making almost panic-brake, I was very surpriced to experience that the car did not respond quick like it should, but came to a stop very poorly. Could there be something wrong with the lines or prop.valve - these are the only parts in the entire system not replaced?
Do you have power brakes on your daily driver? A 69 with standard brakes will not stop as quickly as a car with power brakes.
Sorry, but that`s not part of the problem. I`ve had the -69 for 10 years, and the brakes have been VERY sharp until I had to replace the master cylinder due to leaks. Thanks.
Usually a bad new master cylinder or air in the lines would leave you with a soft or mushy pedal. I suspect you might still have firmness if the master has failed, but first I might suggest you pull the wheels and inspect everything very carefully. Make sure all rotors are spinning true and that you don't have fronts on back or backs on front and make sure all your soft lines are healthy looking and not swollen.
Does the red BRAKE light ever come on even though the fluid level is topped off?
Is it possible that you have a master cylinder out of a power break car? That could explain a bunch. It just seems funny the problems started when you changed the MC
The brake light came on when the MS-problems started, but after I replaced the master + calipters + hoses the light has been gone.
I have not been driving the car since, just testing the brakes around my garage.
Yes, the problems started at that point, but I am certain the MS is not for PB.
I'm kind of wondering about the P-valve or maybe if there is a blockage to one of the circuits. When you have the car up on jack stands, turn the wheels by hand and have someone stomp the pedal to make sure you have braking force on all wheels.
There is no Prop valve on a 69', just the diff warning valve. Did you happen to replace the brake shoes with a "performance" type lining? If so, they need some heat to work well. Also, take the car out and run a few light decel stops to burnish the brakes. Don't make any high decel stops until you do this.
we are talking 4 wheel disc here - no shoe and lining - but the new pads might need some heat too.
