How fast will a C3 go?
Never had anyone beside me to tell me how fast im going but im assuming im 105+ and it still handles pretty well... I try not to change lanes but hey I gotta pass those slow drivers somehow right
...or that ghastly knock-off with all the extra cr@p stuck all over it that's been floating around online this past year or so? The dude that screwed up the latter ought to be welded to the floor. As for the real Greenwood Daytonas, while at first glance they may not be all that pleasing to many an eye, IMHO there's a certain beauty about any functional design that is so bad to the bone that rules makers were soon attempting to slow it down (resulting in the "bobbed-tail" GTO version which was quicker still).
BTW, not to get lost here, for pre-'80 C3's the design of the '78 PC style dam/spoiler package is fundamentally sound; reportedly lowering drag coef by ~15%. However, the factory's soft air dam could use some bracing for extended high-speed use. Haven't had a chance to acquire comparative data yet (only recently got my instruments and my shark will be down for a while longer), but from seat-of-the-pants before & after observations it was easy to realize this package made a substantial improvement to the lift/downforce picture, as well.
...and FWIW it looks fairly good, too.
You theoretical point about consideration of the pitching moment during aero design is well taken, but I can attest from having lost both front and rear wings due to contact and/or failures that I'd very much rather loose the front (as long as it doesn't end up under a tire). FWIW, the coaches/engineers I worked with track-side typically suggested my beginning each race weekend with what they estimated to be slightly more rear wing than could likely be gotten away with (drag wise), initially dialed in the front wings so as to yield aero "push", then adjusted the fronts to reach the best aero balance compromise, and finally sought to reduce drag with less overall wing until lap times failed to improve. Of course, this latter process would invariably unmask additional mechanical grip/balance issues.
All that aside, the bottom line remains that one really shouldn't ever ignore either end of the car aerodynamically. My earlier comment was not meant to suggest that adding rear spoiler alone is the best move.
gas is down in price now, so you gotta be aware....too boot it's holiday season....
the car never had a gasket on the back of the hood, and never had any side metal grill inserts....wide open scoops....
only recently has the center section under the add on aftermarket BB hood bulge, been opened up totally.....
there is no spare tire, which I think would act to allow a air damn in rear under the tail light panel....of course the 'vents' are up top in stock position form the old astro vent setup that never functioned, as it's a a/c car....
so the question is.....overall, that is your opinion of these changes??? do those body mods help or hurt?? the car is stock height, not supposed to be according to VBP with the 460 spring in front, but it is according to frame measurements off the GM literature....
I know it's NOT a C3, but the Calloway Sledgehammer deserves a mention.... as it really was an incredibly fast car.
Keep in mind, that a lot of media attention has been placed on the Bugatti Veyron, as the fastest production car available at present with a top speed of 252mph.
The Calloway sledgehammer, based on a late eighties C4, ran twin turbos to produce a staggering 900 horspower.
It went on to reach a phenomenal 254 mph !!!
And that was in 1988!
Almost 2 decades before the Veyron !!!
Fair bit of good info in link below.... handling the flow of air at high speed was the critical factor in achieving the design goal... not just for aerodynamic drag, but also for cooling purposes, and air intake for engine, and of course, to keep it on the road.
http://www.z06-corvette.com/super/sledgehammer.htm
Interesting to note that John Lingenfelter was the test pilot for the Calloway project back in those days.
any car break that record yet today??? I was joking with my wife that she could drive that to the grocery store and then head out over the Buckman at 240 mph or so......her head spun around grinning.....
120 mph is about all my nerves are good for these days and that's in the LS1 Trans Am. The Vette saw 120 mph about ten years ago. I wouldn't do that now without going thru the suspension as the springs are shot etc.
LOL! I always wear a seat belt in other cars but never in my 72 :-)
Anyhow it will look a whole lot more practical than some of those Greenwood conversions
(note- it has been about 5 years since i last really cracked a physics book. my current job lets me feel all the benefits of physics, but eliminate the math
From the pressure standpoint the distance along the top of the vehicle is greater than that on the underside and thus the average velocity is greater over the top than the bottom. Faster flow means lower pressure, lower pressure means lift. For pressure to build up on the underside the flow must be obstructed, deflected, diffused or stagnated.
On to race cars... Rear down force bias is generally the fastest aero set up since it allows later and harder braking. This reduces the amount of time the vehicle is transitioning from straight to corner. For optimum race car set up you start with the maximum rules dictated tires and work your way up through the vehicle. When done properly, weight and aero (down force and drag) balanced with the tires, chassis, etc. makes for the optimum set up. Lap simulation tools like Bosch's Lapsim make optimization of these parameters relatively easy.
Contact induced, suboptimal set ups in many cases boil down to driver skill and experience. Under steer is probably the best suboptimal condition since it is the easiest to manage.
I prefer to maximize down force at the hardest end to adjust trackside. Then adjust the easy end to driver preference at the track. Rules generally dictate which end is hardest and easiest to adjust.
Cheers, happy holidays and good luck racing!
http://forums.corvetteforum.com/c3-t...post1568309199
Having never been fortunate enough to have benefited from having comprehensive setup simulation software (have run with Pi and Stack acquisition, tho), while finding my way around during the first laps on a given track I found it a good bit less expensive to just follow the initial setup advice given me before moving ASAP to optimizing. As for loosing parts off of the car, if not for providence I wouldn't be here from the rear wing mount failure I suffered at IRP. Had nothing to do with my skill, or lack thereof, and was one of those times when it was definitely better to be lucky than good.
