383 cam help
Old Dec 19, 2008 | 05:11 PM
Al Davis's Avatar
Al Davis
Default 383 cam help
I am building a 383 w/ forged bottom end. 9.5 compression, Dart heads 200, Performer intake (due to hood clearance) Q-jet carb by Cliff. 355 gears, auto trans, Hooker super comps w/ Flowmaster exhaust. I am looking for performance from a 383 that won't destroy my trans, rear end ect. Maybe 425hp. Here are my two picks. Comp 280 Magnum 230/230 470/470. Or I already have a 962/L82 cam that would be 224/224 480/490 W/ 1.60 rockers. Any other I thoughts are welcome. Al
Old Dec 19, 2008 | 08:45 PM
C3 Stroker's Avatar
C3 Stroker
Check out this link.....many ideas and combos here:
http://www.ryanscarpage.50megs.com/combos1.html
Old Dec 19, 2008 | 11:15 PM
mbeeman350's Avatar
mbeeman350
St. Jude Donor '03-'05-'06-'07-'09
I built a 383 with 195 cc Trick Flow Heads, 9.7 CR. I used a Comp retro rolloer .510 lift, 224/230 duration on a 112 LSA. Cam is good, little lope at idle. I have an auto with air so I didn't want to get too crazy. If I had it to over I might be tempted to tighten up the LSA to 110 for a little more lope or go fora little more duration, I have a 308 rear gear. Regarding an intake, ck out profeesional products. I used a polished one with a Holley Street Avenger. The ports matched the ports on the TFS heads and hood clearance was good (running a stock hood). The Perfomer's ports are too small for your heads.
If you are interested I can look up my notes on the model of the intake and measurements on the hood clearances
Just my 2 cents...best of luck
Old Dec 20, 2008 | 11:18 AM
billla's Avatar
billla
St. Jude Donor '14
Specifically which Dart head? What's your diff ratio? It's all about matching the cam to the heads and the RPM range that it needs to deliver in.
Old Dec 20, 2008 | 11:35 AM
Al Davis's Avatar
Al Davis
I looked up the heads, they are Iron Eagle 200. Gears are 3:55
Old Dec 20, 2008 | 06:24 PM
Al Davis's Avatar
Al Davis
bump
Old Dec 20, 2008 | 08:22 PM
billla's Avatar
billla
St. Jude Donor '14
Pretty healthy set of heads
262CFM @ .500 lift, with a max lift of .520 with the 110# springs - all from Dart. If you've got a different spring package, call it out. That kind of lift and flow cries for a retrofit roller if it's in the budget. Anyting in a flat-tappet cam with that kind of lift is going to be a pretty radical cam. You definitely need a stiff converter.
The Magnum 280 (12-212-2) isn't a bad pick with the right converter, nor is the 1.6 ratio rockers with the L82 cam. There's room for more lift to get the most out of the heads...but IMHO not without going to a hydraulic roller.
My $.02...and worth every penny
Old Dec 24, 2008 | 06:12 AM
tapio's Avatar
tapio
Anybody tried the 962 cam in a larger engine, like 383 or 400?
Old Dec 24, 2008 | 09:37 AM
99 Black Bird TA's Avatar
99 Black Bird TA
I would say try to go with the hydrolic roller cam and go over 230 on the cam...probably 236ish intake and ~242 exhaust depending on what your heads flowed etc.
Old Dec 24, 2008 | 11:41 AM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Although I like roller cams more than flat tappets, in either case, pick an intake duration of about 230 to 235 and exhaust duration of about 5 to 10 degrees longer. Pick a lobe separation angle of 108 for performance, or 112 for slightly less performance than economy; 110 deg lsa is a reasonable compromise.
A lumpy or radical idle occurs with the lower lsa grinds.
To 383 cam help
